OBD-II Simulator for Standalone users..
Old Nov 13, 2005 | 08:51 AM
donour's Avatar
Originally Posted by MalibuJack
Technically you're describing what the UTEC already does its just that for as much as I love the UTEC, their really slow on updates I **REALLY** need..
What the community really needs is a general purpose programmable, not just mappable, platform for engine control. EMS's, Motecs, and such are nice, but could you imagine the possilbities if you had a 500 mhz strongarm CPU, 60 channel dedicated DAC/ADC, and 512 mb of nonvolitile solid state storage?
d
Old Nov 13, 2005 | 11:51 AM
MalibuJack's Avatar
d
Are you thinking what I'm thinking?? I saw that GIO board recently too.. hehehe..
Old Nov 24, 2006 | 08:28 PM
joeracer321's Avatar
This thread is old but MalibuJack, did you ever test this to see if it worked. I run an AEM EMS and I thought about using an extension harness to split the essential signals to the stock ecu, just enough to get a few of the self tests complete. I would then install a MAF and send the signal to the stock ECU. There are only a few hang ups: Some of my stock wiring has been re-used to run other things and as inputs for other sensors, but it may be worth looking into.
Old Nov 25, 2006 | 07:04 AM
Matthew333's Avatar
Earlier in the thread, M was talking about loops and contin. feedback issues- ive been experimenting with 555 ic's to feedback data to the factory ecu based on its outputs- the ecu will throw codes when it has no outputs also. (thats a ton of diodes) im still going to toy around, and think I can make it happen. Most of the factory manuals are secretive on the obd II specs- I was trying to figure the comm rate, bit transfer/duty rates to make something else just to communicate with the "man".
Old Nov 27, 2006 | 02:16 PM
althemean's Avatar
I was thinking along those same lines and ran into the same problem. Not enough info on the factory obd-II I/O. I wish something along these lines could be developed. I run the AEM EMS and will have to pass emissions at some point and with JUN cams....i'm not sure a simple reflash of the stock ECU would be the thing. Not to mention the rewiring of sensors...although as an avionics tech...its not that big of a deal. Just time consuming.
Old Nov 27, 2006 | 04:33 PM
Matthew333's Avatar
time consuming.....exactly!!!
Old May 15, 2007 | 05:34 PM
Blue Evo 8's Avatar
I just switched back to my stock ECU today, plugged in the stock MAF, stop map snesor and took out the AEM EMS for the purposes of passing emissions.
I havent driven the car yet but the car throws 5 codes:
P0113
P0102
P2229
P0243
P0106
Can anyone help???
Old May 21, 2007 | 08:50 PM
sub7's Avatar
It may be the old codes stored in ECU. You should try to clear the code and re-read again. Tried OBD Scan Tech?
Old May 21, 2007 | 09:01 PM
Blue Evo 8's Avatar
I got rid of those codes 4 good, now i'm down to 1 code, p0172.....
help
Old May 21, 2007 | 09:51 PM
sub7's Avatar
Error code for p0172, hope this help.
http://www.obd-codes.com/trouble_cod...gen-sensor.php
Old May 21, 2007 | 09:52 PM
Blue Evo 8's Avatar
Yes, I'm already there and even registered there......
Old May 23, 2007 | 01:44 PM
johnjonfenomeno's Avatar
Are you still running your wideband 02 sensor? did u plug the factory o2 into the one where youre wideband is ..
Old Sep 22, 2007 | 06:51 PM
I just wanted to bring this one back from the dead. Anyone do any testing yet on the stock ECU to see what data is being output, whether it stores the VIN# not just the immobilizer code.
ball7068
Midwest Region
May 2, 2010 11:31 AM
CLaNZeR
Jan 31, 2009 02:26 PM
CLaNZeR
Jan 11, 2009 07:32 AM
KOTT
Sep 17, 2008 08:59 AM
MalibuJack
Jul 15, 2005 10:48 AM
