CAT Replacing test pipe =CEL?
Old Dec 21, 2005 | 02:05 PM
REDEVIL's Avatar
Hey fellas i im contemplating the idea on replacing the catalyst with a test pipe, but since there is an 02 sensor after the catalist will this cause a CEL?
Old Dec 21, 2005 | 02:41 PM
RallySport Direct's Avatar
Silver Sponsor
Yes it will cause a P0420 code. You will want a CEL fix. You can do the fouler trick or buy one from us.
http://www.rallysportdirect.com/shop...oducts_id/1147
Ben
Old Dec 29, 2005 | 01:04 PM
stevoviii8's Avatar
www.o2simulator.com
Old Dec 29, 2005 | 01:18 PM
levo2nr's Avatar
Ben
hey can u tell me how ur Aluminum piece can fix the cel ?
i thought it would be a o2 simulator
Old Dec 29, 2005 | 01:42 PM
Silver Sponsor
What it does is it takes the sensor out of the exhaust stream so the sensor sees less of the exhaust gases. I have never had one not work perfectly.
Ben
Old Dec 30, 2005 | 08:43 PM
hondafan's Avatar
Ben
i'll back him on that, i made my own with the foulers, but the same thing basically, over 15,000 miles and no CEL
Old Dec 30, 2005 | 08:45 PM
race17k's Avatar
i agree! did the same with my test pipe and works great!
Old Jan 3, 2006 | 09:08 AM
IMR-TIM's Avatar
I also agree with the fouler setup. I did the same thing to my VIII when I installed the one piece 3" downpipe w/cat elimination. Works PIMP and no CEL
Old Jan 3, 2006 | 09:10 AM
sleet's Avatar
Originally Posted by stevoviii8
+1 I had one of those come with my test pipe, I haven't had a CEL since.
Old Jan 5, 2006 | 10:36 AM
BOOSTEZ's Avatar
Ben
Well, I'm the first then.
I bought one from you back in July of last year and drove the car for a few months and then bang! The CEL came on again with the P0402 code. I'm wondering what's going on with this.
-M
Old Jan 5, 2006 | 10:56 AM
Inn-Tune's Avatar
-M
P0402 is for an EGR issue, not the catalyst inneficiency code P0420 and will not be fixed using this method. Did you simply mis-type the code number and mean to type P0420?
Old Jan 5, 2006 | 10:58 AM
EnJaNir's Avatar
Mechanical o2 sims work majority of the time, but like their electronic counterparts they don't offer a 100% guarantee.
If it doesn't work I would suggest trying to drill a smaller hole in the fouler or soldering some extra material at the tip of the undrilled piece to greater limit the amount of exhaust gas the sensor sees.
Old Jan 5, 2006 | 10:59 AM
ashton13's Avatar
Ultimate racing has a cat delete with a built in CEL fix for like $125
element2zz
13
Jan 2, 2009 06:22 PM
ibarkovic
19
Oct 22, 2008 10:28 PM
mihaley
18
Jun 7, 2008 05:44 PM
wek
Feb 27, 2008 07:01 AM
Trustz
Jul 9, 2003 05:06 PM
