Tunerpro RT irritating me today
Well Im trying to post up some friggin logs I had today and I can't find an .adl file that is suppose to be a log. Now if I hit F4 that will bring up the ALDL setup screen and I can see my different logs in the data logging column. Now what I dont get and there are a few things
1. WTF, is this suppose to be so damn complicated?
2. I hit the "Export Selected Session to CSV and it did nothing. There is no way I can send a log to anyone, I can view it just fine on my laptop.
With all these different files all over the place I am ready to pull out the maftpro and head back to utec, that was set-up more user friendly insted of opening this file and modifiy that file and convert this fiole to read that file. I guess I am at my boiling point with this system. There has to be an easier way to log.
/rant over
Apparently a lot or the Tunerpro rt files were corrupt, not sure how that happened. But I found a way to convert each log to a .csv file. This I can deal with for the time being.
Can anyone make a How-to gude to this thing?
I did find out one wierd thing today and when I was trying to connect to the maftpro my COM1 was being disabled by the palm software (not running). I eliminted the palm desktop and everything worked, I think it was the palm, software not completely shutting down.
/rant over
Before you try to export, start playing the log. I've had better luck doing it that way. Also, the path to your adl file should be shown when you hit the "Select log file for..." button. If that doesn't work out for you, post up what happened when you tried those things and I'll try to help some more.
-Paul
-Paul
xPRimNT
239
Jun 2, 2016 10:40 PM
Tevenor
16
Apr 22, 2008 04:56 PM
rhyzin
Oct 25, 2004 01:51 PM
