Where can i find Evo IX ECU diagram ?
Well, i remember seeing it somewhere, search function is down for me atm... can't seem to find anything..
anyone remember the pin number for the speedometer, need to connec that to my HKS TT..
thanks a lot !
thanks a lot !
Wheee. Ya'll welcome.
https://www.evolutionm.net/forums/sh...1&postcount=14
Hello all! I need this diagram too. HKS told me to check with my dealer regarding the ECU diagram and layout for the IX. I called several dealers in northern Illinois and they told me that the information can't be released because you could essentially steel a car having the entire map for this system. I'm still waiting on one guy to just give me the info on the Speed sensor and the RPM for the HKS TT. I read somewhere that pin 80 was black/yellow and controlled the speed. I'm not touching anything until I can verify. I'll let you know!
Ok. Now I'm all kinds of P-O'd. I called Mitsu direct and no one there was able to help me with this. They told me to check the dealer because they should have all of the info on the IX's. Well, the manager told me that he has NOTHING on the ECU! I'm stuck! Before I got my IX I had an STi (big mistake, I know), but when I needed any info, including ECU, the dealer was able to help. Does anyone have any suggestions?
Sorry I can't help, brother. I'll let you know what I find out!
Ok... Update: I managed to get my hands on the electrical schematics on what I was told was the IX's info. After taking some time and attempting to map out the system, which wasn't an easy task, I then attempted to follow two possibilities for the wires on the RPM for the HKS TT. Well, need-less-to-say, neither worked for me. So, if you're going to try to figure it out, I eliminated the green/red and the white/green wires from the C module. Having failed with these two I didn't even attempt any more. I'm going to wait until I can find someone who has clearly mapped out the entire system because of the 100+ wires that are down there. Sorry...
Guys, that information has not been release from Mits as of yet. I checked in my alldata program and it gives only BS info. I will post on IATN.net to see if some nice mits tech will email me the info.
OKay I have it, but it is on PDF file. anyone know how to load that type of file into here. I can email it to them, then they can post for me. contact me if you want it. Ladykats@gmail.com
I may have an idea on how to put that file on this site. Can you give me the info on where you found it? I may be able to convert the file, but I'm not 100%. Send it to Medix21@yahoo.com... THANKS!!!
