IX intake only
Old Mar 26, 2006 | 02:44 PM
gkmunch's Avatar
IX intake only
I've done a few searches on the forums and have concluded that running HKS RS intake as the only mod on my IX MR will make it run "9/10 lean".
This is something I did not realize until after I had installed the intake, or else I would have refrained for putthing this part in.
How serious of a problem is this? Enough to cripple my car for 3 days to send the ecu out for a flash to richen it up?
thanks for any insight, I really know nothing about tuning, or the results of a 9/10 lean A/F
thanks
Old Mar 26, 2006 | 02:54 PM
Warrtalon's Avatar
That's not exactly what it does. It just throws off the tune by causing lean spots, sucking in hot engine air, and causing turbulent air flow across the MAF. You need a tune to make it useful, so either send in your ECU to get flashed now or re-install your stock airbox until you do more mods and then get flashed.
Old Mar 26, 2006 | 03:00 PM
gkmunch's Avatar
excellent, so I'm not harming anything by having that as the only mod?
I also made the 'air scoop' (sheet metal, curved) to gather air from the front of the car to the stock and air channel, which spits the fresh air right at the filter.
I'm just concerned about doing anything to damage the new motor by running lean?
Old Mar 26, 2006 | 03:05 PM
Warrtalon's Avatar
How would you get that from what I said? Lean spots and screwing up your MAF readings are not good.
Old Mar 26, 2006 | 03:09 PM
gkmunch's Avatar
sorry, I absolutely misread.
edit: it's back to stock until I have the time and resources to do it right.
thank you for your help
AKB_EVO
Dec 12, 2016 08:02 PM
overdrive1
Dec 18, 2015 05:12 PM
LVLANCER
Lancer Aftermarket Forced Induction Tech
17
Sep 5, 2011 06:43 AM
R0b
Mar 21, 2011 06:49 PM
OctaneReport
Aug 13, 2009 06:57 AM
