SAFC@ with aem uego
SAFC@ with aem uego
i was woundering has anyone else just took out their rear o2 out and used the wide band there? what numbers do you get? i also have BR settings and my numbers are high till im really on it
Just curious but wouldnt removing the rear o2 throw a CEL? I would just order a new bung for a few dollars and weld it in about 24 inches from the turbo and run the wideband in there. Thats where i have had the most reliable results at in the past.
Dustin
Dustin
Originally Posted by bongtastic
I would agree, I'd think you'd want the sensor as close to the exhaust port as possible to get the most accurate and quickest readings but not so close as to be biased to a particular port's exhaust .
Good post.
