Big turbo + untuned engine, ok for track event?
Old May 15, 2006 | 06:52 AM
StarOfDeath's Avatar
Originally Posted by robertrinaustin
Probably. Why would you risk blowing your engine by beating on it untuned if you currently can't afford to tune it? If you think the stand-alone is expensive, check out a complete rebuild. It is one thing to drive the car and avoid heavy load or high boost, but you are taking a huge risk by beating on it untuned.
Also, to the guy who said it should be ok becuase it is MAF based, I think you've got it backwards.
What do u mean by a complete rebuild, do you mean strengthening of the engine? Pardon my ignorance
Old May 15, 2006 | 07:14 AM
Originally Posted by Boost Freak
So you can afford the kit and Intercooler, But you cant afford a EMS or a tune? Should have went with something cheaper and better and got a EMS, But to each there own, its your car. But if you have to post about id you should tune your car after you get a turbo kit installed, maybe you should just take the kit off and learn a couple more things. Sorry if this is all harsh, but its the truth.
I mean, when the turbo blew, part of it broken fins went into the intercooler and was damage. Considering that I’ve a ready plan for a major upgrade long before the turbo’s failure. I went a head to purchase the turbo kit, intercooler and fuel system and failing to oversee the shortage in funds I don’t think taking out the kit would be a good idea even though the rationale of it, is for me to learn something.
Cheers
Old May 15, 2006 | 07:31 AM
scorke's Avatar
To be honest you just planned it completely *** backward. Although the turbo blew, you should of been researching/finding what the turbo you were looking at buying needed to run well, and then put the parts on when and only when you had the money to get it tuned.
Scorke
Old May 15, 2006 | 07:37 AM
hostile's Avatar
Run the car on the lowest boost possible. It will be fine, these guys don't even know what engine knock sounds like and they are trying to tell you what parts you need.
On the stock ecu with knock control you cannot tune knock by ear.
Old May 15, 2006 | 07:39 AM
scorke's Avatar
You can tune knock by ear, thats amazing....
At no point did any of us tell him what parts he needed, we all advised him to get some sort of tuning device and make sure his fuel system was up to task before getting on it, if that is not sound advice... I dunno what to say.
Old May 15, 2006 | 07:45 AM
puckadog's Avatar
with your circumstances, it would prolly be ok to putt around... isn't there anyone in your area that can at least give you a decent flash for you mods?
DO NOT track, i assume it's a road track, your car in it's current state. for a track day you definately need a good safe tune... cause you WILL push it. you just can't help it with an evo
Old May 15, 2006 | 07:57 AM
RiversideMitsu's Avatar
You can run the car on 1.25 bar no problem "If" you stay out of boost and drive it easy "NO BOOSTING". Keep in mind If you push the car to 18.38psi (1.25 bar) on that turbo you could push your stock fuel system too hard and lean out. I know on my 3065 @ 14.7 psi I flowed more than my 16g at 22psi. Even with the stock turbo @ 23-24 psi the injector duty cycle is already geting to 90% plus on the stock 560's with a safe AFR on pump gas.
Old May 23, 2006 | 07:58 PM
mchuang's Avatar
go to openecu.org, download the ecuflash freeware or there is also a link on this website, paypal 94.00 dollars to mynesperforance@yahoo.com or go to tactrix.com and purchase an openport cable and you will then have the power to tune your car and drive as hard as you want kapeesh!!!
Old Jun 1, 2007 | 11:50 PM
Ludikraut's Avatar
I can feel my IQ dropping just reading some of these posts... ouch!
StarofDeath - under no circumstances should you be boosting your car with its current setup. _Could_ you track your car? Sure, but it's no fun tracking an Evo below 3000 RPM.
Hopefully you've avoided doing any permanent damage to the engine. Once you've got your pennies saved up, have everything checked out and get a proper tune. Doesn't sound like you've got the dough to take any other route.
l8r)
Old Jun 5, 2007 | 04:38 AM
pltek's Avatar
make sure you you have a bicycle with you cuz you will need it to get home from the track
Old Jun 5, 2007 | 01:38 PM
yikez's Avatar
i can't believe this thread..this has to be a joke!
why can't you just get the damn car tuned?!
Old Jun 5, 2007 | 01:50 PM
High_PSI's Avatar
I bet at 1Bar he would be fine if not a lil slower. Just set it to 14.5PSI until it is tuned.
Old Jun 6, 2007 | 02:00 PM
Mellon Racing's Avatar
please get it tuned before you hit the track or go WOT, you're going to be moving way more air then you did before at the same boost level and are probably running too much timing for that... I have a link in my sig that explains the process, equipment needed etc...
dprez25
Oct 23, 2012 12:51 AM
IXEvolutionIX
10
Sep 3, 2009 06:11 AM
tim85851
17
Jun 25, 2008 10:18 PM
awr
Aug 17, 2007 07:38 PM
