05 Evo MR + SAFC trouble
Old May 21, 2006 | 10:45 PM
vboy425's Avatar
My friend have a 05 evo mr. Today i install the SAFC for him. Every wire is correctly solder and tap. i run a shop and this is the 36 safc i have install. Anyway what was really weird about this is that the SAFC work when the car have just turn on. I can kill the car idle by leaning it out the lthrtl map, but once the car move like an inch and me trying the samethign again even at -50 the car still idle normally. Sometime at stationary i would rev the rpm up and once i let go of the gas, the RPM would stuck and boucning up and down between 2000-2200rpm. I even disconect the SAFC and put everything back to stock. went for a test 3rd gear pull and log it wiht a pocketlogger. It show he's knocking from 3k-6k with a negative number on the timing. I have never seen that beside timing pull, but negative timing
??? WTF.
Old May 22, 2006 | 10:46 AM
vboy425's Avatar
bump for help
Old May 23, 2006 | 08:53 AM
vboy425's Avatar
bump
Old May 23, 2006 | 08:59 AM
speedracer2169's Avatar
What other mods are done to the car? Sounds like maybe a vacum line came lose. Same thing happened to some guy at the track vacum line came off popped it back in zip tied it and voila fixed. Check are your vacum lines
blueo4's Avatar
bump for you that is crazy
check your wiring again and initialize
Old Jun 4, 2006 | 07:27 PM
Mase's Avatar
its probably not related to the afc then
Old Jun 4, 2006 | 10:27 PM
vboy425's Avatar
yes i have check everything. he bought the mr used and it got about 3-4k on it from the dealer. i wonder why the previous owner return it?? he got nothing but an MBC, DP, and cat back
Old Jan 31, 2007 | 10:49 AM
MR_EVO21's Avatar
I'm having the same problem with mine. I have an 05 MR too. If I rev it up fast and then put the clutch in; the rpm's stick at 4000rpm and the go down to 3000 rpm and stick there too. If I rev it up again to see if it will release it but it works some of the time. I have HKS blow off, MBC, Drop in filter and then the SAFC II with plug in play harness.
Old Feb 1, 2007 | 10:40 PM
vboy425's Avatar
wow old thread. anyway yeah some SAFC are defective. anytime this **** happend to my customer. I just swap the SAFC out with another one and it works.
DSM97HERO
Sep 21, 2008 06:24 PM
evo ippo
Feb 5, 2007 12:44 PM
silverEVO8
Oct 23, 2006 03:02 AM
EVO-genetik
18
Jun 11, 2005 02:28 PM
BaLListic_EVO
19
Apr 30, 2005 08:12 AM
