What is the easiest way to read engine timing
Old May 25, 2006 | 10:41 AM
Jeff_Jeske's Avatar
Question What is the easiest way to read engine timing
I have the XEDE but have no way of reading my overall engine timing.
I have tried a pocket logger but it seemed to be very slow to react.
Is there a freeware OBDII software package that will work with a cable of some kind that will allow me to monitor timing - - real time?
I imagine I will have to use a laptop and that is fine.....I just need to know the product to use.
Old May 25, 2006 | 09:12 PM
SlowCar's Avatar
when i had my evo8, it was flashed with ecutek and i used the utec to log timing, boost inj duty..........works out real well...AFR too
Old Jun 1, 2006 | 05:01 PM
trinydex's Avatar
this may be a bit late but the problem is that the only way to read timing on a stock ecu equipt vehicle is through the odbii port. this is slow, sample rate of less tan 20 samples a second. this requires you to capture timing several times to get a good overall picture of what you're running.
unfortunately the pocketlogger is the only way right now, or a similar odbii cable. wait for the ecuflash software to address logging... then it'll be a nobrainer.
Old Jun 1, 2006 | 09:39 PM
EVO8_PR's Avatar
Thumbs up
ECU+ does a pretty good job.
Old Jun 2, 2006 | 07:58 AM
Jeff_Jeske's Avatar
I've been watching the ECUFlash information. There goes the resale value of my XEDE.
Old Jun 6, 2006 | 02:05 PM
C6C6CH3vo's Avatar
For stock ecu tuning esponses so far are:
  1. ecutek flash + utec
  2. ECU+
When, what, and how much would this be?
So does this mean that you can monitor what really happens after ECU processing from map changes made with the ecuflash?
Old Jun 7, 2006 | 03:39 PM
trinydex's Avatar
apparently the program is almost done and it looks fantastic. search evolog and open ecu.
it means exactly that
