IX specific thread
Old Jun 1, 2006 | 09:56 AM
MRIX's Avatar
Question IX specific thread
Can we have an IX specific engine thread? I'm trying to find who is using what on the IX but these gems are lost in the non-IX posts. Also, in talking to the various vendors, I get the feeling that they are still learning what works and whats redundant with IX mods.
I'd like to get specific answers to IX related things like:
1) who is getting what HP wise on the dyno and with what mods?
2) what dont we need to do with and IX? (e.g. does a new muffler really add much, once you have got rid of the boost taper?)
3) who is taking advantage of the IX's significantly upgraded ECU? How and to what effect? Has anybody figured out how to get the IX's ECU to do real time boost control etc etc. Are piggy-backs now redundant given the increased capability of this ECU?
4) do we really need an upgraded fuel pump with the IX or is its higher capacity fuel pump already OK?
5) are the IX's rod and head studs OK or do these need to be replaced for high RPM and/or boost as with previous EVO's?
Old Jun 1, 2006 | 11:35 AM
yellowbirds58's Avatar
^ those are cool questions and i would also love it if they combined it all into one or made a thread that did only relate to the Evo 9's but i think we're about to get flamed soon
Old Jun 1, 2006 | 11:44 AM
mrdevo9mr's Avatar
Why not?
I also would love a specific thread for the IX. It is a different car from the IIIV and it would make information easier to find for those of us with one or for those interested in getting one.
Old Jun 1, 2006 | 12:43 PM
thetox's Avatar
It really depends on what mods you are putting on the car and whos tuning it. Some people like to stay mild while some like to go wild. Just for reference here is my bone stock IX on a Dyno Dynamics dyno that was flashed by Shiv from Vishnu.
http://forcedfours.com/showthread.php?t=214
There are tons of threads that show examples of power made by IX's with very little mods. Checked out www.forcedfours.com in the Vishnu section and you will see some of the results from the Dyno4mance dyno day of other IX's that had exhausts.
http://forcedfours.com/forumdisplay.php?f=22
A new exhaust will help a IX but an exhaust alone will not make the power that adding an exhaust and a tune will add. The IX ecu does not react the same way to just adding an exhaust like the VIII's do. Boost taper will occur any time you are using the stock boost solenoid. It will also happen when using an MBC but not to such a great extent.
In my opinions Vishnu is taking advantage of the ECU the most with their ability to work with MIVEC and produce good smooth numbers. Other companies are working with it as well but some of the best results that I have seen have come from the Vishnu camp. Not man piggy backs are out for the IX at this time. I believe Motec and another company have piggy backs available for the IX but don't quote me on that. AEM has not yet released a standalone for the IX and vishnu is currently working on its harness so that XEDE can be used in the IX.
I believe the IX fuel pump is still the same but I could be wrong.
The bottom end is the same as the VIII as far as I know. Any time you run high boost/rev's you will want to upgrade certain engine components. I do not know if Mitsu upgraded anything in the head with the addition of MIVEC. I did see a thread on here about the pistons being different but I would have to search for it and find it.
-Adam
Old Jun 1, 2006 | 12:44 PM
sesso's Avatar
its a higher capacity fuel pump but only by 25 lph . I was told IX are good till 400 hp on the stocker. but I upgraded cuz its cheap
Old Jun 1, 2006 | 12:47 PM
sesso's Avatar
the head is a different design and is watercooled.I would think that they upgraded the bolts but I'm sure al told me to get the head bolts.again cheap insurance
Old Jun 1, 2006 | 01:02 PM
thetox's Avatar
They changed the design of the water passages on the IX head and this has helped make the IX less knock prone as well when compared to the VIII....or so Ive read
Rumor also has it that the stock muffler design is different and higher flowing than the VIII was...once again....or so Ive read
Edit: and just another addition...Upgraded metal BOV so there is no more stock BOV leak once you hit 13+ psi or whatever the VIII BOV leaked at.
Old Jun 1, 2006 | 01:31 PM
MRIX's Avatar
Nice response Thetox!! Thanks for the info.
Looks like we may have the beginnings of an IX specific thread here anyway.
Old Jun 1, 2006 | 01:41 PM
thetox's Avatar
No problem. Id be glad to provide any info that I can. There is also a very good ACD thread on here that Terry S created but that is more drivetrain related. Does contain info about how the ACD reacts when in the different modes.
just for reference.
https://www.evolutionm.net/forums/sh...ht=ACD+article
One thing I would like to get a definite answer on is the range of timing that MIVEC utilizes. Ive heard that it is variable from -15 degrees to +15 degrees(infinitely variable within that range), but I would like to get a definite answer on the range of timing that is used...and the actual range of timing that is utilized while driving. Anyone happen to know this?
Old Jun 6, 2006 | 11:12 AM
res04's Avatar
IX MR = 295 AWHP after Shiv tune @ Vishnu , Greddy Ti cat back, Works HFC and Tanabe 2.75 DP.
What not to do? Intake or filter.
Old Jun 7, 2006 | 07:53 PM
devolutionist's Avatar
I agree. A IX specific forum section would help me greatly in my search for knowledge for my car. The IX posts do get lost in with the gazzillion posts for the VIII. Any possibility of this??
Old Jun 7, 2006 | 08:01 PM
thetox's Avatar
you dont need an intake...filter is fine, but if its an oil bath filter make sure the excess oil is removed so you dont screw up your MAF. the stock airbox has been proven to be good for over 400whp...I <3 how good my car feels after shiv worked his magic on it too...270 awhp with just a flash
i also agree that a IX specific section would be sweet
Old Jun 7, 2006 | 08:12 PM
bizzarro's Avatar
hi fellas,i think its a great idea ,since most of us rookies would like to learn more ,like what clutch ,injectors with what set up,thanks
Old Jun 7, 2006 | 08:24 PM
555R's Avatar
evolutionmr.net
but not alot of people surf there
turbotrix just dynoed an IX 374 hps
with tbe and their cams
i am all over that
payway87
43
Sep 9, 2014 03:50 PM
DynoFlash
24
Apr 13, 2009 10:44 AM
Chabada15
Jun 9, 2008 04:49 PM
beemerfreak
May 22, 2007 05:04 PM
MrBonus
12
Apr 24, 2004 11:34 AM
