Problem with UTEC
Old Jun 28, 2006 | 10:31 PM
MalibuJack's Avatar
Originally Posted by SubiEvolved
I just picked up a openecu cable and flashed the car back to stock. Car was def never flashed back to stock but it is now.
Drove the car down the road and the CEL came on and have the same problem. This is real annoying!!!!!!!!!!!
Another thing i noticed is the problem only occurs in map 0 (passthrough). In full thottle in map 1 (stage 1) it is fine. If i do 1/4 throttle on map 1 it wont go past 4500 though.
Maybe the wiring to the MAF is screwed up? But if it is then why on the stock ecu alone it is fine?
Its unlikely.. make sure you dont have any crimped wires, make sure the utec programming switch is in run mode..
I used to get an error with the UTEC when I was running a beta firmware, in passthrough mode I'd get a CEL error for a baro sensor, it wasnt passing the signal through correctly... you might have to test it on a different car to be sure its a bad UTEC.. its possible you sent back your UTEC, they serviced your unit and sent back the same unit and never found the actual problem..
It can be an intermittant problem, 1/4 throttle is about the crossover point so I would still look at your configuration, maybe a bad map, or corruption, or something else..
are you using an OLF map and OLF is disabled? Same with boost control, did you have closed loop boost control map and its still open loop?
Old Jun 28, 2006 | 10:51 PM
SubiEvolved's Avatar
How do i tell whether it is in run mode or program. I thought the car wouldnt even start in program mode?
It is def not my old UTEC. It is a brand new one. I called TXS and asked them myself. I am running OLF and i have a Electronic Boost Controller so the UTEC doesnt even control boost.
I doubt its the map because WOT is fine and map 0 (passtrhough) is the problem.
Maybe im having a problem with voltage. The code is a low circuit input. Can the UTEC be drawing that much power from the car where is cant read the MAF? Maybe there is a problem in the maf wiring harness? Engine grounds? The car does infact have a small battery kit and the alternator has 96K miles. Just some ideas i thought of but i am no means a mechanic.
Old Jun 29, 2006 | 07:40 AM
MalibuJack's Avatar
Its possible the input voltage is very low, and therefore not enough to be regenerated... but my experience in the past was firmware not correctly regenerating the signals in passthrough mode..
Anyway, the car will start and run in program or run mode.. however in program mode there are some quirks you would see, since its expecting a programming sequency the logger may display unexpected data, or the maps may not save when you try to..
This may be anomolous, but do you turn the key and immediately crank it? I used to have problems with the MAF not initializing fast enough and throw CEL codes (and run poorly and in open loop)
If you haven't tried this... Turn the key, wait for the CEL Light to flash your map number (or just wait 3 seconds approx) then crank the engine.. see if that helps.. It may be something that simple....
Worse comes to worse we can arrange to get you out to my shop here on Long Island and go over the car more closely than could otherwise be done.
Old Jun 29, 2006 | 07:43 AM
MalibuJack's Avatar
Oh and another thought... IS your ECU scaled for new injectors? If it is, did you also set the scaling on the UTEC? There are two scaling settings in the UTEC, one represents closed loop fuel MAF offset, the other represents the OLF injector scaling for the maps... Its possible when you switch at that threshold your basically cutting fuel to the engine or flooding it due to unscaled injectors.
Old Jun 29, 2006 | 12:20 PM
I actually flashed the car with your stock rom jack. The utec scaling is set at 550 in the OLF parameters.
The car is in run mode and not in program mode. I switched it to program mode and it wont start....
Old Jun 29, 2006 | 01:43 PM
One Wicked EVO's Avatar
we swaped out the utec and installed it in my car and the utec is working normal on my car!! so a bad utec is not the case!! the car only goes into limp mode when the utec is installed but not when the stock ecu is in!!!
Old Jun 29, 2006 | 04:34 PM
I also sanded down and went over all my engine grounds.......
Old Jun 29, 2006 | 06:49 PM
MalibuJack's Avatar
Damn, then it very well could be something in the wiring harness.. Do any of the wires look crimped or kinked anywhere?
Oh, and swap MAF sensors.. And worse comes to worse, see if you can swap ECU's.. Maybe there's really something wrong with your ECU or the MAF?? Now that we can reflash the ECU's, swapping with another car is easy..
Old Jun 29, 2006 | 06:51 PM
MalibuJack's Avatar
Look for stupid stuff like ignition problems too.. Who knows at this point..
Old Jul 3, 2006 | 11:56 PM
Ive also recently realized that my dipstick keeps popping up. I wonder if this has anything to do with it? However like I said I only get that code with the UTEC plugged in. Been driving the car all day without the UTEC and no problems.
ERIK
Old Jul 5, 2006 | 10:07 AM
MalibuJack's Avatar
You dipstick popping out can be caused by
1) PCV Valve stuck
2) Vent tube blocked, kinked, or whatnot
3) Excess blowby under boost..
Probably unrelated...
You have any plans to come out to the Island any time soon?
Old Jul 5, 2006 | 11:05 AM
David Buschur's Avatar
I would guess a valet mode or rev limit is engaged too. Nothing else really makes sense. Have you talked to Turbo XS about it yet?
Old Jul 5, 2006 | 02:28 PM
Was on the phone all last week with them. Car isnt in valet mode when it does it. Also the rev limit was set to stock and no launch control on. I PMed you back dave.
ERIK
Old Jul 5, 2006 | 04:29 PM
MalibuJack's Avatar
You know something.. there is that extra wire that comes out of the map switch for the Subaru launch control feature, I cut that wire off so it wouldn't get in the way... Have you looked at that? Or on the switch?
With everything basically disabled, the only thing I can think of is your crossover point and something weird with your injector scaling.. Can you set the crossover point to something higher or lower and see if that affects it?
