throttle point setting
Old Jul 10, 2006 | 06:00 AM
leary123's Avatar
can some explain to me how the throtlle setting works on the safc2 i mean u define high and low throttle but from factory its set 10 %low 50?%high so what happens in the middle i ask becuase when i put a blower/turbo on the car what is a good way to set the throttle postion as i wont need to do anythng in low throttle
Old Jul 10, 2006 | 07:23 AM
EiEVO's Avatar
How this works:
If you set LOW to : 10%
And HIGHT to: 50%
Then: from 10% to 50% you will be in the low throttle adjustment range and from 50% to 100% you will be in high throttle adjustment range.
On my evo i have it set at: Low 35% High: 60
Being the car under normal driving conditions will not build boost under 35% and easy driving so i need no adjustment there.
Old Jul 10, 2006 | 08:03 AM
leary123's Avatar
well helpfull thanks
Old Aug 26, 2006 | 12:42 PM
cpoevo's Avatar
Originally Posted by EiEVO
How this works:
And HIGHT to: 50%
That is not right. If you set your LOW to 30% any throttle up to 30% will be your on your LOW settings. If the HIGH is at 60%, 60% throttle and above will be on your HI setting. Anything between the 30and60% will split the difference between the HI and LOW settings.
Old Aug 31, 2006 | 12:56 AM
vboy425's Avatar
+1 on cpoevo.
Old Sep 12, 2006 | 09:41 PM
Charlie3g's Avatar
Originally Posted by vboy425
+1 on cpoevo.
I agree
Old Sep 12, 2006 | 09:51 PM
DRFTKNGG's Avatar
So for the settings you will want something more like....Low@60% High@90%...?
Old Sep 12, 2006 | 10:23 PM
cpoevo's Avatar
I set my low at 30 and the hi at 65.
nothere
Nov 8, 2014 03:20 AM
dan l
Apr 3, 2007 01:12 PM
dryad001
49
Mar 24, 2006 05:25 PM
cyberninja
10
Aug 7, 2005 07:15 AM
LancerEVOmann
Jul 7, 2005 06:32 AM
