Resetting the HKS Super AFR
Old Oct 29, 2006 | 03:33 PM
spudlus's Avatar
Resetting the HKS S-AFR
Does anyone know how to reset the HKS SuperAFR to original settings so that I start from the beginning programming it?
All of a sudden when in monitoring mode it's seeing the RPM as twice what it should be, if RPM on tach is 2K, the SuperAFR is reading 4K. Of course this is screwing up the AFRs of the car and puts it in danger of engine damage.
Any help is appreciated.
Thanks.
Old Oct 29, 2006 | 05:26 PM
spudlus's Avatar
It's not clearly stated in the manual but if you switch it to "learning" mode by setting DIP switch 4 to 'off' it will automatically ask you for the cylinder settings on the next power up. Don't forget to switch it to 'on' once the learning is complete.
Old Sep 29, 2007 | 10:56 AM
TakaseEVOIXSE's Avatar
i actually just purchased one of these from a member... cant wait to get it in and install it! assuming you have had success w/ this device?
awdordie
17
Feb 26, 2017 09:16 PM
SWOLN
Oct 15, 2015 11:07 AM
fugiwara
Aug 23, 2010 09:47 PM
evoracerx
11
Jun 28, 2004 09:33 PM
SLOPOK EVO8
Oct 10, 2003 07:26 AM
