Just installed some upgrades on my IX MR
Old Nov 19, 2006 | 11:15 AM
2Devious's Avatar
Yesterday I finally got a chance to hit the auto hobby shop and do some installing.
Installed:
TTP 3" Downpipe fully exhaust wrapped
Megan resonated testpipe
Megan catback
Mechanical CEL fix
Forge UNOS MBC @ 22psi
Buschur Intake pipe + filter
Jestr M1 tune
The TTP downpipe fit ok, it cleared the oil pan perfectly but is VERY close to the TC. It is also touching the frontmost bottom tie-bar. The wrap might actually make it all look closer than it is. I'll have to space out the tie-bar and tweak a little to move the downpipe a bit.
The Megan stuff all fit without a hitch and was a pretty easy install. The o2 sensor was a serious pita to get out of the stock cat, had to use a sensor tool and an impact wrench =/. No CEL lights though!
Took a bit of tinkering with the MBC and my Evo15 DV. Finally ended up with the soft spring in the MBC w/ 25 clicks and the blue spring plus one shim in the DV. She is holding 22psi very well with almost no taper. Had the stronger springs in for the first test run and spiked at 30psi ... ouch. Blew the UICP off the intake manifold on the way back to the garage. Man, it builds pressure fast, spool time was greatly reduced. Quick set of spring changes and all good now.
The Buschur intake pipe and filter all fit up real nice. Just had to do some fanangling to get the DV all hooked up to the stock UICP and the intake pipe. And by fanangling I mean chopping up a stock hose to make it work. The sound is great. Can really hear the spool up and it has a nice whoosh from the DV. Not too loud.
The Jestr M1 tune is running great. Did a 1-5 WOT run and only got about 4 counts of total knock the whole run. That's much less than I was getting on the stock tune. Very happy with the tune!
So, my mini review:
TTP DP and Forge MBC from TTP
Megan Resonated Test Pipe and Catback from, the man, Zeus
Buschur Intake Pipe + Filter
Jestr M1 tune wow, what an amazing bang for the buck tune.
Next weekend will be track time to see how my times improved.
Old Nov 19, 2006 | 11:24 AM
allricedout's Avatar
nice, what do you mean by auto hobby shop?
Old Nov 19, 2006 | 11:30 AM
2Devious's Avatar
Sorry, it's a military thing. We have a garage on base where you can rent a bay, w/ or w/o a lift, and all the tools you need for $3.50 an hour.
Old Nov 23, 2006 | 06:38 PM
Kay@kacework.com's Avatar
^thats sick...
Old Nov 23, 2006 | 06:42 PM
Evoryder's Avatar
good stuff...one of the perks of the military...
Old Dec 10, 2006 | 07:04 PM
vmrevo9's Avatar
Veteran: Air Force
yeah they do come in handy!! i'm at Moody AFB. Tyndall is in florida right?
tim85851
Aug 20, 2011 10:00 AM
hmsevo9mr
Mar 24, 2011 09:33 AM
diddyX
13
Feb 15, 2009 06:40 PM
IDRNKV8
33
Jan 23, 2009 08:21 AM
Cali2MDevo8
May 4, 2007 09:07 PM
