Tuning Selection for Newbie
Old Jan 29, 2007 | 10:33 AM
jfitzpat's Avatar
Originally Posted by joshesh
What is the need for the wideband senor? It is 200 bucks and I thought all you need is the cable for 90? Cant you log with just a cable and a laptop? What does the wideband sensor let you do that you cant do without it?
The O2 sensor in most cars is a 'narrow band'. It basically tells you if you are running at stoichiometric (roughly 14.7:1) or not, to satisfy the emissions control equipment. Running against this sensor is called 'closed loop' operation.
When you stomp on the pedal, and hopefully get a reassuring push back into your seat, you are operating 'open loop'. The ECU is trying to guess at actual airfuel based on things like air flow. So the values in the fuel maps are really just guesses, rather the values are entered as "AFR" or not.
In a turbo vehicle in particular, WOT air/fuel mixture is a balancing act between cooling and power. Knowing where you are actually running becomes critically important in performance tuning - especially if you starting doing mods to injection, induction, or exhaust.
In addition to now being a 'core metric' (having largely replaced EGT, which used to be used to try to determine actual lambda/AFR) for performance tuning. A wideband can potentially tell you other things as well. For example, I see even single ignition misses as clear spikes, and detonation as high frequency ringing (helping me distintuish between real and phantom knock counts). But these things are secondary. Even if your wideband or sensor location do not give them to you, you are still getting a critical performance measurement.
-jjf
Old Jan 30, 2007 | 06:00 PM
Forevapmp's Avatar
isht.... I'm sold.... looks like i'll be picking mine up soon......
Old Feb 10, 2007 | 09:35 PM
Happy Hazard's Avatar
-jjf
Excellent information, thank you for taking the time to type this out. It really helped to clarify, at least for myself, the proper steps in which I would like to go in my tuning. I knew I wanted to log my data and build from there, so I guess going with a wideband and tantrix cable will be one of my first steps.
Thanks again.
COBB Tuning
137
Oct 7, 2011 12:59 AM
COBB Tuning
Oct 25, 2010 08:12 AM
DrivelineSales
EvoX 'For Sale' External Engine / Power
193
Jan 19, 2010 02:29 PM
RallySport Direct
Nov 29, 2008 08:19 AM
Slowride
Dec 21, 2006 04:29 PM
