MSD DashHawk?
Old Mar 5, 2007 | 09:16 AM
tribe's Avatar
Question MSD DashHawk?
Anybody try the MSD DashHawk? Looks like an interesting device to help tune our cars. The EVO is not on their supported vehicle list, so I don't know if it will work with our cars or not. Was CAN bus available on the EVO8?
http://www.dashhawk.com/
Old Mar 5, 2007 | 09:17 AM
ak47po's Avatar
Do evos have these pins.
Locate the OBDII connector. It is under the dash on the driver’s side of the vehicle, often either under the steering wheel or tucked up next to the driver’s side kick panel.
Look carefully at the plug with a flash light or other bright light source. If pins 6 and 14 have metal pins in them (i.e. are “populated”) then the vehicle has a CAN bus and DashHawk will most likely work with this vehicle.
Old Mar 5, 2007 | 09:41 AM
tribe's Avatar
On my 2003, pin 6 is not populated, but pin 14 is populated. Not sure if this is for all EVO8/9 or just 2003. The DashHawk has the features I've been looking for:
display of OBD parameters
warning lights for OBD parameters
small form factor
check/reset OBD codes
external sensor input (ie, wideband!)
Anybody else find a similar device that works with an EVO8? The Greddy Infometer and Apex iMoni can't check/reset OBD codes or support external sensors.
Old May 18, 2007 | 05:17 PM
Evo_Evo's Avatar
I know what you are looking for. Check out the Nitrod VPM-100G.
I good mine not to long ago and I just love it.
My03evo
Aug 26, 2011 12:29 AM
khaydin
Sep 23, 2010 01:46 PM
joeymia
38
Sep 5, 2007 05:08 AM
namahs
105
May 9, 2006 12:32 PM
ct9a gsr
12
Jun 1, 2005 04:26 PM
