Test Pipe or high flow cat
Dear All,
This is my first time post in here , i got some questions for my 06 EvoIX(MR).
I want to know is the test pipe is better or High flow cat is better, because i already put the down pipe, o2 housing, test pie and cat back exhaust for my evo but i go to think if i put the HIGH FLOW CAT on my car, is it have any preformance on there ?
do you guy think WORKS high flow cat is better ? or is that same performace the factory Catalytic Converter or do i need change back my factory Catalytic Converter put on my car
how come i want to change back high flow cat on my car because i find out my rear bumper have very dirty after i change the text pipe
Tks
Tks
Getting it tuned will lean it out and keep the soot off your back bumper. HFC's don't really do much anyway. Kind of like a mid point between a TP and stock cat. Half as loud as the stock cat, cleans the exhaust about 1/2 as much as a stock cat and robs about 1/2 as much power as a stock cat.
Get it tuned. Not only will it clean up your exhaust a little, You'll notice a HUGE difference in power with those bolt on's.
In Denver you are all good with a test pipe as emissions is only every two years and cops aren't ba!! busters about emissions usually (at least that's my experience with my catless wrx).
If you are concerned at all about inspections, you could purchase a straight section of 304SS and gut the inside of the high flow cat, and have the straight section run through the inside and then welded up. I know catco cats were 3" inner diameter, and a 3" outter diameter pipe fit inside of them absolutely perfectly. Tig weld the end together, and now you have a test pipe with the visual appeal of a HFC to an inspector.
Hi
I run a HFC, I have not noted any performance decrease over a test pipe. In the UK it passed our emissions test very easily, if you are concerned about your emissions, a good HFC is the way to go.
MB
MB
