WORKS Tune Dyno Numbers
WORKS is helping me build and prepare a car for the Targa Newfoundland Rally in September. They've helped me tune the car for the event, and I posted the most recent tuning numbers to my blog for those who might be interested:
Almost-final Tune by WORKS
The tune is still pretty conservative, and was done on 91 octane fuel. Relevant mods include:
- Injen Intercooler and LICP
- WORKS throttle body
- Cosworth Cams and WORKS valvetrain parts
- Tanabe Concept G turbo-back exhaust
Check it out.
Check it out.
Hi Peter how are u doing
I got the quesions from you , after you mod your car , did you car have the CEL come on be4 , because i have EVO9(MR) but my car already have 3 times CEL is on , when i check the code is said Engine Over Boost. Tks
My Mod is Fujita intake and LICP
WORKS Aperture Throttle Body
Tanabe down pipe, Helix o2 housing , Helix Test pipe
Tanabe cat back exhaust
HKS SSQ Bov, and WORKS Brain Flash P2.
I've not had a check engine light from the WORKS tune yet. Could the overboost problem have something to do with your blow-off valve install?
There really is no need for an aftermarket BOV on this car. Hopefully you have it recirculating as well, because that will obviously cause issues if not. I would swap back to a stock BOV and see if it has any affect.
Most likely, the CEL is caused by your test pipe, our TR303 and TR340 packages with WORKS Exhale exhaust system and WORKS High Flow Cat will not throw a CEL.
Feel Free to call me up at the office if you have more issues.
1. There is a dip in the curve after peak boost that seems to overlap a dip in the hp and torque. If Works are running ECU boost control with their excellent pill, adjusting the WGDC tables slightly higher in that rpm range might take care of this dip, unless there is something else that is causing it.
2. I do not think that your AFR is rich. Your car is ~ at 12:1 AFR at peak boost and is above 11.4:1 AFR throughout the rpm curve. I do not think that is rich for 91 octane gas.
Congrats on your tune.
the XI bov works just fine for basic mods cuz its metal. People changed evo 8's cuz they were plastic and would leak. If you are looking for more sound out of the BOV then just purchase an open air filter such as buschur racing for 80 bones, and your bov will be more noticeable. Good luck.
