map switch question
Old Jun 5, 2007 | 08:59 PM
sekula's Avatar
map switch question
Hey guys, so i have the map switch and just wondering, but what are the two other sets of wires that are connected to the switch. One set is black and red wires that just sit there, and the other set are 2 wires with these 2 connector things on the ends of them. Thanks!
Old Jun 6, 2007 | 05:17 AM
MalibuJack's Avatar
Don't worry about the extra wires, the one coming off the map switch is for the launch control feature, but the Evo doesn't need it, so you can leave it disconnected. The other wires are for activating a relay, read the documentation to get more info, its all there. (you can download it off TurboXS's website if you don't have it)
Old Jun 6, 2007 | 09:18 AM
sekula's Avatar
o but what if i want to use the launch control feature/flat shifting feature, do i have to connect those wires to something, and if so, what? thanks
Old Jun 7, 2007 | 09:16 AM
[EVO]Cookie's Avatar
No you don't have to use the wires. The Evo launch control works of the clutch switch. Turbo XS has a PDF manual you can down load off there site. Better get it it's the only support your going to get from them.
Igaly1021
Jun 5, 2016 06:25 AM
fwd_josh
May 26, 2014 07:06 AM
stunt2
Aug 9, 2013 11:34 AM
wizzo 8
Sep 10, 2009 11:58 AM
ChuckP
Aug 10, 2009 01:42 AM
