What about this setup?
Old Aug 26, 2007 | 04:38 PM
mscorei's Avatar
Lightbulb What about this setup?
Hi, I have the following mods on my car: Milltek catback, test pipe, Milltek downpipe, Invidia o2 housing, HKS SSQ bov which came with the upper i/c pipe and EIDS. As you expected my car is running rich, so I'm willing to change that.
I want to buy the Injen kit with the cone air filter and all the pipes lower and upper i/c pipes and go back to stock bov. or recirculate the hks ssq?? or buy the forge evo type rs bov?
After i want to do an e-tune. Buying an Walbro 255 lph High Pressure Pump will improve performance also? what about fuel consumption?
Please tell me your opinions about this setup, and give suggestions if have any. 10x
Old Aug 27, 2007 | 12:06 PM
Mellon Racing's Avatar
I would go back to the stock IX BOV which is fine until you run much more boost.
The fuel pump will not improve performance, it just allows the fuel pressure to keep up with the engine's demand. Once you install the fuel pump you'll need to be tuned so I would get that done at the same time as the other mods so that you get it tuned once.
Old Aug 29, 2007 | 05:53 PM
mscorei's Avatar
what about a boost controller. does it help to gain some performance?
mscorei's Avatar
i would like to buy the injen kit with lower and upper i/c pipe, is it worth?
Old Aug 30, 2007 | 11:15 AM
mscorei's Avatar
bump!
Old Aug 30, 2007 | 01:44 PM
yes, but cranking the boost up without being tuned for it is a no no
Old Aug 30, 2007 | 08:39 PM
mscorei's Avatar
which boost controller would you recomend to that setup I mentioned above; I intend to tune it, but before I have to put the parts in the car.
P.S. i have put back the stock bov, it runs much better.
Old Aug 31, 2007 | 01:47 PM
buschurracing.com has some inexpensive but good MBC options
nzmusclez
Aug 23, 2016 04:33 AM
Alex54
Apr 5, 2012 02:23 AM
GreedMOTO
Sep 28, 2006 07:59 AM
EVOVIII200
Mar 25, 2006 01:17 PM
ev08buoy
11
Sep 12, 2005 06:05 PM
