ok tried this in the general section..cat to testpipe
so my car was tuned with a cat in place. i am going to put in a testpipe. i am assuming i will not need a re-tune to run the test pipe??
a friend of mine has an s2000 and has the same situation..tuned for a cat putting in a testpipe..apparently his car will run lean now?? ithought it was the opposite and would run rich..
http://www.s2ki.com/forums/index.php...ic=528129&st=0
It will actually run a little leaner due to the increased flow. The buffer of safety left in your tune will determine the need for re-tune. Monitor knock if you have the means, but I think you will be fine.
Clipse3GT
Jul 2, 2009 07:12 PM
Autogasm
Oct 16, 2005 06:25 AM
