ApexI SAFC POLL - Please Respond
Old Oct 9, 2004 | 12:17 AM
  #166
TrikeDOutEvo8's Avatar
Ok....to let u guys know....i just got a brand new AFC...first gen...gonna install it tomorrow...but i dont understand on how to to tune it....if someone is runnin the same mods as me and has an AFC, can they please help me out with it....im not too good with tuning yet...Mods Are: K&N cone filter, MBC, and BOV...and workin on gettin an exhaust...but dont have it yet...gonna go look at gettin a custom one tomorrow...so a lil help would be wonderful...thanks guys
Later,
Jay
Old Nov 10, 2004 | 07:37 AM
  #167
EVIL MR's Avatar
vivid racing are you setting also works on 2005 evo thank you.
Old Nov 10, 2004 | 08:17 AM
  #168
Vivid Racing's Avatar
WOW! Did not know this thread was still rockin... About a year old
Yes the settings will work on the 2005 MR, RS, and EVO VIII. The small differences in the MR will not greatly affect it as these are pretty conservative. The EVO is the same minus a couple extra features. So yes these settings will work.
If you have ANY questions or need help just give us a call!
Old Nov 10, 2004 | 09:31 AM
  #169
ebbeast2005's Avatar
So im running turbo-back exhaust w/ test pipe, 21 psi, greddy types vta, intake, ic piping 93 octane live in Wv weather is top 100 on hot summer day but it does get cold. If any1 has good number please pm me with them
Old Nov 10, 2004 | 11:26 AM
  #170
EVIL MR's Avatar
thank you. i have hks rs intake do i need to add gas from 2000 to 3500 i heared that this intake will make it lean in that range
Old Nov 12, 2004 | 06:23 PM
  #171
EVIL MR's Avatar
up
Old Nov 12, 2004 | 06:36 PM
  #172
EVIL MR's Avatar
Originally Posted by MalibuJack
Yes... you can actually use positive settings.. It depends on load and peak boost but if you find you get a bit of knock at certain RPM's, then you should be adding fuel.. Also don't forget there's a LO-THR setting to allow you to set a curve of compensation based on throttle position (this way if you find you need a certain compensation at part throttle, and different at WOT, it will interpolate the space between) I have yet to see anyone tune for part throttle open loop compensation for drivability where most of us are driving.. I find that even when I'm testing WOT runs, I find that I'm frequently not at WOT the whole time, hence tuning for those things will improve drivability and performance.
how can i find out what knock happen on what rpm it gose by so fast
Old Nov 14, 2004 | 06:12 PM
  #173
Whats safe settings with my mods please help im installing today!!!!
Old Nov 15, 2004 | 02:40 PM
  #174
berkel's Avatar
Sometimes I'll clear out the stored value, then set it to display the highest attained setting. Start at 3000 rpm then go WOT, back off if you see the knock spike and make note of the rpm.
Does that makse sense?
~lates,
FB
Old Dec 9, 2004 | 04:55 PM
  #175
mattfl's Avatar
Dunno if anyone is still reading this..but I just got a safc today..mods are just a hks rs instake, and bov. wonder if anyone has any settings for similar mods? or if anyone knows a good tuner in the daytona/orlando area
Old Dec 9, 2004 | 05:13 PM
  #176
EVIL MR's Avatar
do you have mbc or ebc
Old Dec 9, 2004 | 08:03 PM
  #177
mattfl's Avatar
neither..the boost holds at 19psi up thru redline however
Old Dec 10, 2004 | 06:47 AM
  #178
mattfl's Avatar
actually, this has changed as of this morning i ordered a hallman MBC..which should be here next week.
Old Dec 28, 2004 | 08:46 PM
  #179
2MANYCARS's Avatar
Mine is:
Lo Throttle: 30% Hi Throttle: 60%
4000 -2% 4600 -3% 5200 -4% 5800 -5% 6400 -8% 7000 -11% 7600 -13%
So far so good, even in the cold weather on 93 octane. No SES ever.
Mods are: HKS RS intake, HKS 2.5" DP, UR 2.5" TP, HKS 2.9" Catback, Cusco oil catch can, and JDM MR Bypass valve.
Old Apr 20, 2005 | 11:07 AM
  #180
superman105's Avatar
