Official EVO AccessPORT Information from Cobb Tuning
Ok so Cobb has repaired the AP connector and shipped it via UPS ground. Its not going to arrive until Tuesday . They also included the boost line and updated the AP with the new stage 2 93 v100a. THANKS COBB . Hopefully everything goes well.
Quick update - Today I received the AP from Cobb and everything is working properly now. So i installed the cobb TBE and Cobb intake then flashed the stage 2. The gains are awesome, the exhaust tone is awesome and the intake is awesome. Intake bracket was confusing to install since there was no instructions but we got it to work. I held back from installing the o2 housing for now but will do in a few weeks.
The intake installation was pretty straight forward. It came with a bracket that bolts to the same location as the stock bracket that held the intake box. You also have to reuse the stock bolts that held the map sensor to the intake box.
Not sure if I gained any power from it but the sound is totally different. If you like the swoosh sound then this is for you. I'm not really into the sound, it causes too much attention but I am pretty sure I gain some power. I'm sure a tune will bring out more power out of the intake.
for another awesome cobb product.
is the new intake sound akin to when those srt-4 neons roll up on me and rev just to make that blow off sound...is it that loud...or are we talking it only enhanced the relatively quiet sound of the bov.
I wouldn't mind the intake/bov sound a little louder....but not from a 1(stock rating) to a 8 or 9 sound.
Thanks for the report
I got the boost gauge installed today and we think the gauge is bad. After the initial lite up sequence only the needle stays lit and not the numbers...they don't even lite up when the lights get turned on ........I also set the warning light on the gauge to come on at 22psi and the thing lights up at like 15psi......
Have you had these issues at all with the gauges?
Thanks
Also, how have you liked your STRI gauges?
Thanks
Thanks
STRI Wires------Radio Harness---------Wire Type
Red wire----------Red w/ Black stripe--------Constant Volt
Orange wire-----Blue w/ Yellow Stipe-------Ignition On
Yellow wire-------Green w/ white stripe-----Illumination
Black wire---------Bolt near radio-------------Ground
Well, i found out why the gauge wouldn't lite up fully when the car lights are switched on.
I always have my nite-time dash lites set very low ( the dial underneath the steeringwheel), so last nite when I was switched the lights on, and the gauge still didn't lite up I decided to move that dimming dial all the way up....as soon as I did that the gauge numbers all lit up....so at this point during the day it seems just the needle stays lit....then at nite the gauge will be lit up only after I move the dimming dial to FULL Brightness.
Since I have never had a boost gauge before (obviously) I am still learning how to read this thing....it seems like my boost is all over the place....it will hit 21.5psi most times when at WOT but at others...mainly 1st and 2nd gear it only get to like 16-18psi. I''l probably take one of the guys at IA for ride to see if this thing is actually reading out right or if the gauge is bad.
oKay sorry for gauge talk back to AP stuff
I wonder why it doesn't ping at peak in those gears?
could be the ecu doesn't allow full boost in 1st or 2nd...but those gears always seem to pull just as hard if not harder than 3rd/4th......of course that could be because of shorter gearing
COBB can you guys chime in on this?
I'll tell you what I'd hate to be a Tuner/Performance Company.....too many darn people like me out there you have to cater to
