Do EVOs sux that much....
Old Dec 6, 2007 | 03:56 PM
  #46
vovinamer's Avatar
i've driven with ac on highway only to a city and it was like 25mpg... i average 21-22mpg... not too bad i guess..
Old Dec 6, 2007 | 03:57 PM
  #47
vovinamer's Avatar
by the way i check my mpg like everytime i fill my gas up... i just reset the odometer everytime i fill up and divide what miles i drove by the amount of gallons i filled up.. =)
Old Dec 6, 2007 | 04:05 PM
  #48
UT_Evo's Avatar
The tripometer you mean... I averaged 17-25 depending on driving style and type (excluding the track, of course). Now I average about 15-23
The EASIEST way to get good gas mileage out of the Evo is to get an MBC and turn it all the way down and try to stay out of boost as much as possible, cruising 80 in 5th on my way to and from Vegas is how I hit ~25ish.
  #49
1sik _evo8's Avatar
im getting like 200 220 in a full tank
Old Dec 6, 2007 | 04:13 PM
  #50
EMonz57's Avatar
Originally Posted by Box Rocket
I'm averaging about 200 per tank. Sucks. I was about 230 for a long time. I added a BR air filter kit (only performance mod) and not immediately but overtime it dropped to where it is currently.
Been seriously debating a reflash to see if it helps.
garentee the flash will help quite a bit. these cars run so damn rich from the factory my AEM uego wideband couldnt even read the AFR. all i would see was the most rich the guage could go and that was 10.1
Old Dec 6, 2007 | 04:28 PM
  #51
freddiet's Avatar
To answer a question the guy said about the evo is kinda light. There is no kind of light car. There is a light car, and there are "Other" cars. A miata is a light car. The evo is not a light car. My ex-wife on a drive from washington st. to PA. she got about 320 a tank, she also put us behind! When i would drive i would get about 260 a tank and that is goin 90 mph. So i think the slower you go on the highway to keep Tach down. Like just go 70. (boring) You can get better gas mileage. If you were really worried about gas mileage you would go just 70. And if you are goin to go just 70 and not have fun. Trade in your car and get a prius!
Old Dec 8, 2007 | 02:13 AM
  #52
gtfour43's Avatar
I hit 95 in my rental Prius on my last vegas trip . Ran it 350 miles with 1/4 tank left and filled up only took $20
Old Dec 8, 2007 | 03:28 AM
  #53
grandhust1in's Avatar
I get about 220-250 depending on the driving. Does it suck that much?? What were you driving before a prius?
Old Dec 8, 2007 | 05:05 AM
  #54
Owens Racing's Avatar
I want to add to my response of getting close to 30 mpg. I am currently playing with ECU Flash. I noticed that my AFR at a normal hiighway speed sit around 14.7-15.0 nothing less then 14.7. This is obviously cruising low load.
I ma curious anyone else have a wideband that can post up there AFR while cruising at highway speeds?
Old Dec 8, 2007 | 06:57 AM
  #55
EVOL2003's Avatar
i get between 18 and 22 or 23....mods below, mostly around 20 mpg on average
Old Dec 10, 2007 | 09:00 PM
  #56
EvoTech's Avatar
Stoichometric is 14.7 to 1 so this is exactly what your ECU is aiming for at cruise. It is what I see consistantly at cruise.
Old Dec 12, 2007 | 07:51 PM
  #57
itzcharlez's Avatar
hrmm... getting 215 miles to 11 gallons..
around 19 mpg...
mostly city driving. stop and go.
im guessing this is around normal..
Old Dec 12, 2007 | 08:13 PM
  #58
StealthaPsYcHo's Avatar
I usually get 250+ sometimes less of course, gotta have fun sometimes
STUNNA#1
Aug 14, 2016 05:25 AM
EvoOtto
Oct 29, 2015 07:13 PM
NJRalliart
Feb 8, 2011 12:57 PM
JDM EVO PANAMA
Site Feedback / Suggestions
Nov 24, 2010 11:08 AM
