Mid throttle knock at 2500-3000
Ok... I've been logging when I drive to work and I've seen knock in the 2500-3000 under the 70-90kpa load range. The knock is about 2-5. I'm one of the lucky ones that get to run 91oct gas. ": (
I've pulled a degree of timing from these cells and the surrounding cells to try to reduce/eliminate this.
Anyone else seeing this???
dWiGhT
dWiGhT
I see a similar thing at partial throttle around those loads but at WOT its fine so I quit worrying about it. Try logging a couple of WOT pulls from 2.5 - Redline, that will paint a much better picture of what needs to be tweaked. BTW, I am running 92oct on a stock 9.
I see this a lot as well. One of the popular guys in ECU forums (JohnBradley, NJ, EVO-Kid, ect) posted that this is pretty common. I know I dont usually hit over 3 knocksum so I am not incredibly worried about. MY car isnt really tuned though.
ya just keep taking out 1 at a time until it disapears. Or just decrease your open loop low load throttle map so you go into open loop at part throttle.
I would try decreasing timing first.
sno_evo
25
May 11, 2015 12:09 PM
