aem uego cant log with evoscan, need help
Old Nov 30, 2007 | 02:37 PM
skold's Avatar
setup:
aem uego
black wire to body ground and to serial cable
blue wire to serial cable
Serial cable set up
rj 45 cable cut and soidler to aem out puts, shared ground with body
rj 45 then goes to a rj 45 - 9 pin serial adpater then to a serial to usb adapter
usb - serial adpater is a iogear
cant log wideband at all im running vista on my laptop,
any input?
Old Dec 5, 2007 | 03:57 PM
skold's Avatar
any one?
Old Dec 5, 2007 | 04:04 PM
jrsimon27's Avatar
you need to set the comms on your laptop
Old Dec 5, 2007 | 04:50 PM
BABYEVO 8's Avatar
mine wouldn't log at first.. I had to make sure I had the most recent drivers for the USB adapter.. (i am using the one from radioshack) and then I rebooted my computer with the USB attached.. it found it and I was logging in no time.
I have mine permanently hooked up to usb jacks where the ashtray used to be.. just plug in USB and log away!
Old Dec 6, 2007 | 08:52 PM
skold's Avatar
you have vista,
comms were set
SnailSpeed
Jul 23, 2017 12:35 AM
tscompusa
Nov 5, 2015 05:24 AM
mac_05evo
Mar 8, 2014 08:09 AM
HaVoC RR
10
Feb 19, 2011 11:19 AM
evokid511
Oct 29, 2009 07:08 PM
