Tuning / logger cable? What the hell do i have??
Old Dec 8, 2007 | 06:12 PM
AlphaMale's Avatar
From: Michigan, Indiana, depends on the time of day.
Ok, so i got this cable from a friend a while back for free. I'm trying to figure out what software i can use with it. Does it look familiar to anyone?
Please note the pins are facing you so they're directly OPPOSITE of what the pins on the OBD2 plug would be... comprende??
I will figure out which pins on the obd2 plug associate to which pins on the serial plug later if i need to.
Old Dec 8, 2007 | 06:27 PM
Deepseadiver's Avatar
Check ECU Flash! in the tuning section. You can find more info also at www.aktivematrix.com http://www.aktivematrix.com/forum/
Old Dec 8, 2007 | 07:03 PM
AlphaMale's Avatar
Done, thanks!
Old Dec 8, 2007 | 07:05 PM
MalibuJack's Avatar
Its probably not an RS232-JOBD2 connector.. Its more likely the cable from a scantool or one of the obd2 scanner modules.
Old Dec 8, 2007 | 07:07 PM
AlphaMale's Avatar
If i remember correctly it was hooked to a 2g data logger.
I don't exactly care what it came from, i'd like to know what i can DO with it.
Old Dec 9, 2007 | 05:28 AM
90GSX-03EVO's Avatar
Possibly from PocketLogger?
If I remember correctly, that was the gender orientation (on the DB9 side) that my PocketLogger used.
deeman101
Mar 3, 2021 07:56 AM
Richard.Son
Dec 10, 2015 07:33 AM
Fireescape
Aug 16, 2014 05:55 AM
neilm
Nov 1, 2011 02:54 PM
acamus
Jul 14, 2011 10:18 PM
