ZT-2 Lcd screen slow!!!
Old Dec 21, 2007 | 01:21 PM
ixbreaker's Avatar
is it just mines or is the refresh rate kinda slow on the screen...i mainly just use it for peak hold cuz it lags when i do a pull i don't know what afr i'm at....my buddy has an innovate, and man...that thing flickers so fast and is super accurate...
is there anyway to adjust the refresh rate? or get it to show other parameters like WGDC or load....etc that would be cool but i'm dreaming
Old Dec 21, 2007 | 02:50 PM
skiracer's Avatar
In the zt-2 software on your laptop, go to SETTINGS, then Plot Settings and Comm Port. Refresh rate setting should be there.
Old Dec 21, 2007 | 03:18 PM
ixbreaker's Avatar
wow...i c...thanx a lot ski racer...did this bother you too how slow it was? what setting did you change it too...?
Old Dec 21, 2007 | 03:57 PM
ixbreaker's Avatar
doh!...i still have the same problem...i figured out that the method ^ you gave me only adjust the computer screen...i guess i should've been a little more clear... i have the anodized mini screen that the zeitronix sells...that screens refresh rate is mad slow...thanx anyway...anybody know how to fix the little screen?
Old Dec 21, 2007 | 04:16 PM
skiracer's Avatar
Hmmm....mine doesn't seem to refresh slow. Wonder if you have a problem with the display unit itself. If you bought it from RRE, bring it back to them. I had a problem with my LCD screen before and RRE swapped out units for me no questions asked.
Old Dec 21, 2007 | 05:20 PM
Zeitronix's Avatar
The LCD refresh rate is 3 per second. It's a Liquid Crystal Display . The LCD module is made by the same manufacture in Japan, which makes I-pod displays but even with best temperature specs the laws of physics and laws of liquid crystals apply. So when it is very cold it seams to be slowing down some.
On other hand our ZR-1 and ZR-2 gauges are using LED technology with 4/second refresh rate on the inner digits, which is pretty much human perception rate for the digits. The outer leds on the ZR-1 and ZR-2 gauges are refreshed at blazing 74/second, same as the Zt-2 refresh rate for each value.
Old Dec 22, 2007 | 01:16 PM
ixbreaker's Avatar
^ wow...thanx for the quick response.
methkilab
Jan 4, 2015 09:26 AM
chrisb07
Jul 1, 2013 09:38 PM
slimjim1804
Jan 20, 2013 12:36 PM
Evo_doer
May 6, 2004 11:55 AM
