2 step
Old Feb 29, 2008 | 01:09 AM
EvoVIII808's Avatar
2 step
Where can i find the 2 step for the PFC D jet. under setting 5 i have the abbility to select the box.
Enable / Boost Switch (SW4/ AN8) / Anti Lag ( SW3).
right now the box says
-32 ING Anti Lag Retard
0.63 INJ Anit LAg
Not sure how to these functions work with the PFC.
Below that is a note::
* Antilag is not supported by all PFC's and feature has been removed from FC box's made after 16 oct 2005.*
IS there anyone with antilag active on there evos? i had it on my stock ecu but not sure how to tune it into the pfc.
Thanks for the help in advance.
Old Mar 20, 2008 | 08:53 PM
h22gordo's Avatar
I am also interested in finding more info. on this.
Old Apr 2, 2008 | 06:05 PM
mymigi's Avatar
interested in this info myself.
Old Apr 2, 2008 | 06:08 PM
ELYTEVOIII's Avatar
ditto! LOL
Old Apr 2, 2008 | 11:40 PM
paulr33's Avatar
the antilag in the datalogit is not supported and doesnt work
dont bother trying it - its a waste of time - they coded it and it only worked a few select model PFC's so its not compatiable. that function is removed in later releases of FC Edit etc.
If you want 2 step limiter with spark cut bang bang style launches check out the Gizmo launch interface from apexi - it will work with the PFC fine also check out the Bee*R rev limiter - it does the same thing. if it was me i would go for the gizmo box as its new, more support, documentation etc.
this is covered in the powerfc faq also;
http://paulr33.skylinesaustralia.com...owerfc-faq.htm
Old Jul 15, 2008 | 12:18 AM
yasir's Avatar
Ive used both gizzmo and BeeR, and I prefer the BeeR as its more hard core and interferes less during driving. Gizzmo's full throttle/no lift shift feature is laggy btw shifts and I feel it cuts off power for wayyy to long during a shift. Plus, in a drag race, I sometimes shift with the clutch pedal only partially disengaged, and even then gizzmo used to cut off power, which was very frustrating as the car used to bog down. I wudnt suggest the gizzmo for a big turbo evo...
as for BeeR, its very simple and easy to install and also lets u adjust how aggressive you want the ignition cut to be...
Old Aug 13, 2008 | 04:10 PM
EvoVIII808's Avatar
nice, i almost purchased the Gizzmo, and the shift light. Good thing i waited. BeeR is it.
Old Sep 6, 2008 | 02:31 AM
Yorl8's Avatar
I also have a Bee*r installed on my evo, simple and nice to use
Old Sep 8, 2008 | 02:04 AM
EvoVIII808's Avatar
havnt got mine yet. still working on my fuel Trim and Base Map. having alittle trouble with the program and base map setup
monkeyevo
Aug 25, 2013 03:37 PM
theprofessional
Feb 14, 2012 06:53 PM
jdtsunami
47
May 31, 2011 04:59 AM
clappton
Dec 31, 2008 12:42 AM
s10v8
Dec 24, 2007 08:13 AM
