Knock sum on 93
Old Mar 26, 2008 | 04:52 PM
tk2481's Avatar
Knock sum on 93
I finally installed my accessport with the new vac lines and wow what a diffrence. Not only does it have alot more power but my rough idle problem is gone. Its soo much smoother running now. I flashed it to stage 2 93 octane and while watching my knock sum it would hit 1 then go to 0 then 1 again then up to 2 then 0 again is this normal or should i reflash to a 91 octane map??
Old Mar 26, 2008 | 04:59 PM
Magnumpsi's Avatar
That is not too bad. Get protuned.
Mitch
Old Mar 26, 2008 | 05:51 PM
tk2481's Avatar
alright one more question does anyone know if you can use the accessport for datalogging? Ive noticed that a few of the subaru guys are datalogging with ecuexplorer hooking directly up to the accessport. Can the evos do that or no?
Old Mar 27, 2008 | 12:36 PM
CPA5's Avatar
I just responded to you over in the COBB FORUMS......so I'll just say what Mitch said sounds correct
Old Mar 27, 2008 | 05:02 PM
tk2481's Avatar
Anyone know the answer on the datalogging question i asked? I read on here from a post from ams that cobb has software that will allow you to do this. Is this the streettuner software thats not out yet or something else?
Old Mar 27, 2008 | 05:08 PM
Magnumpsi's Avatar
Just buy a Tactrix cable and log that way with Mitsulogger. I only say this because I am not sure if Cobb has any Street tuner software out for the AP yet.
Cheap and easy and will tell you everything you need to know.
Hope this helps.
Mitch M
2012_Evo_X_GSR
Cobb AccessPORT
Mar 22, 2014 01:21 AM
Hydroyo
Cobb AccessPORT
Jan 8, 2014 06:19 PM
ChipperEvo
Cobb AccessPORT
Dec 2, 2012 07:33 PM
mrfred
39
May 18, 2011 05:05 PM
ant_turbo
Sep 25, 2006 03:08 PM
