3" GM maf and MAFT setup w/ AP ??
Old Apr 8, 2008 | 12:33 PM
phat_bastage's Avatar
Hello,
So over the winter I have added quite a few mods. - I have roughly 30 days or so until my appointment with Christian@cobb to get my car Pro-tuned. Ive kicked off an email but having talked to Christian I know hes a busy guy so maybe im just being impatient, so I figure Id throw it out to the community.
Now, I picked up an evo specific MAFT box and a 3"GM maf for fairly cheap, and Im wondering if the Tuner software will work with the maft setup? If so are there any other steps thats need to be done?
I can still run the stock setup, but I would like the GM maf for a bit quicker spool, VTA Tial 50mm. - Im in no real hurry, but I like to get things done if I have them.
As always whatever input is appreciated.
Old Apr 9, 2008 | 09:31 AM
goosey2099's Avatar
I'm kinda in the same boat, just with ecu flash
Old Apr 10, 2008 | 09:24 AM
goosey2099's Avatar
bump
Old Apr 19, 2008 | 08:57 AM
raiceboi697's Avatar
i just got off the phone with the guys over at cobb and they said that if the car will run with it on the stock ecu then the AP can use it.. the only problem you might run into is if you have the maftpro box where you can tune at that, and even then if you zero out all the setting on that box so all it does is translate the MAF signal you are still good.
cats2cars
Oct 6, 2015 08:22 AM
hediki12
Nov 6, 2009 11:16 AM
dennyt4
Apr 7, 2008 09:55 AM
joosdawg
Jun 17, 2007 12:13 PM
