SM4 locked!
Old Apr 10, 2008 | 11:58 AM
sub7's Avatar
SM4 locked!
My ecu is tuned by a vendor with a password lock. Each times when I require minor adjustment or re-tune due to mod, I got to pay extra $ and quite a distance travel to the workshop.
I insist to learn and tune myself, so I asked for the password but no luck. Out of frustration, I would rather erase my current cal/map and start from ground. Does anyone know how I could trigger the ecu in boot mode and erase the current cal, so I can store a new cal myself into the ecu?
Old Apr 10, 2008 | 12:04 PM
hellcat's Avatar
Not sure about the Evo 7. If it were an 8 or 9 you could find your immobilzer code, and which rom you have and reflash it with a stock image. On 8's and 9's its very important to have all the info you need before you try to flash it.
Old Apr 10, 2008 | 12:05 PM
zbomb's Avatar
He's not running the stock ECU
Old Apr 10, 2008 | 12:08 PM
hellcat's Avatar
Ah, I see, should have picked it up when he said it was password locked. There should be a reset either way.
Old Apr 10, 2008 | 12:22 PM
sub7's Avatar
That's right, I'm using Autronic SM4 (universal) with evo7 harness...
Sorry if my statement confuse you...
Old Apr 10, 2008 | 04:43 PM
Hic's Avatar
Hic
any autronic dealer can do that for you (erase), and also, must give you STARTING MAP. then you are on your own.
but....why do you need MINOR adjustments ALL the time, only god knows....(I can't believe you are changing cams or exhaust EVERY week, so you need retune).
Old Apr 11, 2008 | 06:45 AM
sub7's Avatar
I could easily get a base map to start my engine. I know any Autronic dealer can do that for me... but as I said, I want to do-it-myself. You were right, I dont change "something" every week... but there's always preference how well the idling is doing, launching, boosting and other fine-tuning. These sort of fine-tuning can never be perfect done by any tuner (since he use dyno-tune instead of road-tune). There's always room for improvement for every now and then.
Old Apr 20, 2008 | 05:57 PM
4G63DSM's Avatar
find a new tuner..
Old Apr 25, 2008 | 08:53 AM
gtauto's Avatar
Just go into the software online and choose open file and select a cal which you want to overide the existing cal with password.
Old Apr 25, 2008 | 10:03 AM
sub7's Avatar
that works! This round is mine...
Old Apr 26, 2008 | 09:46 AM
gtauto's Avatar
Cheers
Old May 20, 2008 | 11:33 AM
project_skyline's Avatar
Def find a new tuner. Tuners who put locks on YOUR ecu's aren't worth dealing with IMO.
Old May 20, 2008 | 10:24 PM
sub7's Avatar
That's true, he who trust the tuner should trust owner too.
Old Feb 15, 2010 | 06:32 AM
Oracle1's Avatar
Does that override the current map?
The current map is locked, how do I get around this, do I need a new base map? If so, where can I get this?
SK
Driv200
Jun 18, 2018 02:50 PM
Keng_v
Cobb AccessPORT
May 15, 2016 11:41 AM
CottageLifer
Outlander Sport
Apr 29, 2016 08:19 AM
sideway180sx
Apr 24, 2011 06:51 PM
FastAzzEvo
Jan 29, 2009 04:43 PM
