Power between winter and summer? (temperature changes)
Old Apr 16, 2008 | 12:23 PM
chriseacrett's Avatar
Can't seem to find the information that I am looking for, so....
Just wondering if your car is tuned for winter, what sort of power differences are you looking at once temperatures start changing? I realize every car and setup is different, but just wondering if there is some sort of "1% per 10 Degrees" relationship
Seems like since my car was tuned (when it was 30 degrees all the time) and now (50-70 degrees) my car seems a lot slower and so I want to get it back up to about where it was when it was 30 degrees
Old Apr 16, 2008 | 12:41 PM
spumoni1984's Avatar
it really shouldn't matter that much. the thermodynamic properties of air do not change significantly enough ( >1%) at the operating ranges of your car. Have you changed anything else recently?
Old Apr 16, 2008 | 01:45 PM
Well, I put in BC 272 cams and got it tuned, it ran awesome for like maybe 4 days, after that it didn't seem nearly as fast. I don't know why, I have been logging and everything seems to be good, I have checked almost EVERYTHING that I can think of. There was a vaccum line that came off the EGR (it was the one on the right side) I put that back on and it seems to idle better, but still not as fast. The exhaust manifold started turning white, and plugs were a little white too (so, I would say that it has been running a little hot) but no knock, at least very little anyways, and usually didn't happen much. I thought it may be the gas so I started getting 93 oct. Shell V-Power, less knock but still slow. I am going to clean the throttle body today, really black and sticks a little, but I don't think that is it either. The only other thing that I can think of is I got bad gas, the vaccum line on the EGR came off caused the engine to run hot, and cracked the exhaust manifold. I just haven't taken it off yet to see if that is what the problem is...
Old Apr 16, 2008 | 01:49 PM
DoughtCom's Avatar
I personally notice a major difference between temps. I live in TX and one day it'll be in the 40's the next the 70's and you can tell the difference a lot. I'm not a tuner... but think of your intake charge fighting against air coming in that's 30 degrees cooler. Makes sense to me you would be making a lot more power.
Unfortunately I don't think there's anything that can be done. Get a bigger FMIC move to Canada?
Old Apr 17, 2008 | 11:21 AM
Well thats what I mean, the only real difference that I can tell that happened from when my car went from running good to bad was when it started heating up my 20-30 degrees.
Although, I did not notice that the actual intake temps rose that much, only a few degrees. So I don't know...
honki24
Jan 11, 2024 03:27 PM
Raceghost
Aug 10, 2018 10:39 PM
05_VIII
Sep 29, 2011 12:46 AM
crcain
46
Mar 8, 2010 07:35 PM
