Help! No ObdII with autronics? How to pass emissions?
Old Apr 24, 2008 | 10:28 AM
500hpOnPumpEvo's Avatar
So I have a friend that will pass my emissions test, but here in mass he needs to hook up the ODBII port just to make sure there is no Check Engine light..
Any Ideas?
besides bringing in another evo with stock computer??...
Old May 21, 2008 | 08:49 PM
casper980's Avatar
Sounds like a problem, let us know how it works out.
Old May 21, 2008 | 09:16 PM
nothere's Avatar
your friend has a bit of returning to stock in front of him. register the car in another county/state, maybe grandmas house?
Old May 22, 2008 | 11:51 AM
How about tossing in a stock computer and having it tuned.. basically to idle.?
I think that's the route i'm going to try..
Old May 22, 2008 | 11:54 AM
Nez136's Avatar
This is my plan if the day ever comes for me.
Old May 22, 2008 | 11:56 AM
zbomb's Avatar
Unfortunately that is going to be your only option. It is not only going to have to idle but not throw any CEL's.
Old May 22, 2008 | 04:35 PM
nothere's Avatar
I can tell you from personal experience, you can pass obd2 with an anti fouler, a high flow cat, small cams (maybe big too) and a good tune.
{a good tune that can hold off the cel}
there is a thread where there is talk of overriding the ecu so it thinks all is well, actual use of that flash is a ways off.
automatic you need the maf, might as well use the stock air filter box.
as far as anyone knows you will not find a secret gizmo to get a standalone to pass obd2.... that is why I went back to the stock ecu.
Old May 22, 2008 | 04:43 PM
1slowevo's Avatar
unfortunately the only way you can get that baby to pass emissions
Old May 22, 2008 | 05:00 PM
zbomb's Avatar
True and not quite true. The HKS FCON which is a standalone can maintain the stock ECU to maintain compliance for OBD2. Unfortunately the "popular standalones ie. AEM, Autronic do not share that ability.
Old May 22, 2008 | 05:36 PM
nothere's Avatar
its good you corrected me, thanks, I know I didn't know that.
is it sort of like a piggy back? does it allow the ecu to throw a cel?
Old May 22, 2008 | 05:51 PM
zbomb's Avatar
Nothere, Kinda taking this a little OT but.....Check out ths thread For some more detailed info. I've thought more than one about going this route and having DB tune it. One downside depending on who tunes your car is that the FCON can only be tuned by a HKS authorized tuner.
Old May 22, 2008 | 05:56 PM
tripperfx3's Avatar
Are there any counties that don't require emissions near you? If so and you have a friend that lives in one of the counties you can "move" to his house and register the car there. I had to do it with my 240sx back in GA.
Old May 22, 2008 | 06:00 PM
1slowevo's Avatar
he is in Mass. they go by state emissions here unlike NV where you can get away with County. (I just moved from Vegas to Boston, so I know how that goes)
Old May 23, 2008 | 05:15 PM
Bimmubishi's Avatar
Which Autronic computer is it? Is it a plug-in Group N type or one that has a proprietary harness?
Old May 30, 2008 | 07:35 AM
No it's a PNP...uses factory harness..
