TUNE yes or no??
Old May 13, 2008 | 08:10 PM
2ndnunn's Avatar
TUNE yes or no??
i got a 06 ix and im about to put a header, turboback, and turn the boost up to 20PSI will i NEED a tune or is the car safe with the stock tune??
Old May 13, 2008 | 08:15 PM
03RRVIII's Avatar
get it tuned......dont turn the boost up with out getting it tuned, your timing & fuel needs to be twicked to run that amount of boost.......
Old May 13, 2008 | 08:16 PM
EVIL MR's Avatar
Turn the boost to 20??? stock is 21.
Old May 14, 2008 | 07:50 AM
2ndnunn's Avatar
mine peakes at 19psi??
Old May 18, 2008 | 09:27 PM
recompile's Avatar
A tune is strongly recommended, but at modest boost levels, you will remain safe... just slow
Old May 19, 2008 | 12:36 PM
mac214's Avatar
Tune it so you can get the most benefit out of the things you are doing. Even a completely stock car can benefit from a tune, and once modded, if you don't tune, you will be leaving a lot of power on the table.
Old May 19, 2008 | 12:38 PM
philevo's Avatar
Its always best to tune...
Old May 19, 2008 | 12:42 PM
2003lancerevo8's Avatar
when did Evo's get headers?!
lol :-)
Yes, install the parts and get a tune to get the most out of your modifications.
Old May 23, 2008 | 08:03 AM
porsherules911's Avatar
i know the 06's peak at 20psi i believe and taper to 17 but the 03-05's were slighty lower i dont remember the exact figure.
Old May 24, 2008 | 02:38 PM
amak87's Avatar
stock IX's peak at about 19.xxpsi and taper to about 17.xxpsi by redline. If you install just a TBE w/ testpipe. Your car will peak over 20psi w/o any aftermarket boost controller. Don't even bother w/ a boost controller unitl you get your tune. And dont waste your money on a cheap MBC that will taper horribly. Look into getting a GReddy EBC Profec-B 2 or getting your car tuned w/ ECU boost control.
Personally, I would hate to see you waste money on aftermarket "headers". If anything, just get your stock one ported until you upgrade your turbo.
Getting a tune will definetly help out. But whoever you get your tune from, make sure they know what they are doing when it comes to your MIVEC map. Tuning Mivec is the key around a solid IX tune.
Old May 24, 2008 | 02:43 PM
RAZOREXPRESS's Avatar
A tune makes all the difference!
Old Jun 3, 2008 | 12:21 PM
amak87's Avatar
edit* for my earlier post.
with a IX, you can use a MBC, w/o the bad taper. Just make sure your tuner, knows how to tune your Mivec map for this...
Old Jun 3, 2008 | 12:23 PM
bigpzz's Avatar
if you are going to turn up the boost high you better tune it....made a mistake on my other cars
cumminsracer14
Dec 2, 2016 02:53 AM
cnote2
Cobb AccessPORT
Jun 13, 2016 04:35 PM
aboogabooga
Northeast Region
Oct 1, 2009 04:41 PM
littlegif1
AEM EMS
Feb 17, 2005 09:01 PM
