Evo AccessPORT Beta Firmware Update...
Old Jul 26, 2008 | 07:03 PM
  #61
hytek369's Avatar
Originally Posted by CPA5
^^^^^Bump for an answer^^^^^^^^^
bump
Old Jul 28, 2008 | 07:58 AM
  #62
CPA5's Avatar
I have been absent from the boards lately....and I don't see an update to the firmware....so I want to find out....Has there been a final fix to the AP Firmware that addresses the LTFT/STFT & the Performance Section Readings (0-60 / 1/4 mile time)???
Thanks COBB
BUMP AGAIN
Old Jul 28, 2008 | 01:15 PM
  #63
Rob@cobbtuning's Avatar
I'm not sure what version is currently running on your AP.
1. Power up your AP.
2. Go to the about screen and look at the "Firmware" version.
3. Compare the current firmware version of the AP to what is listed on the website here: http://www.cobbtuning.com/info/?ID=3874. The current version of Mitsubishi AP firmware is 1.2.7.1.
Thanks,
Old Jul 29, 2008 | 08:28 AM
  #64
CPA5's Avatar
Thanks,
Rob---
Thanks...i can definitely check it out...But...does the version 1.2.7.1 have all the bugs worked out? i.e. the fuel trims and the 0-60 & 1/4 mile performance stuff?
Thanks
Old Jul 29, 2008 | 08:35 AM
  #65
Rob---
Thanks
Yes, it should.
Old Jun 30, 2009 | 10:45 PM
  #66
silverguy's Avatar
cool will install latert tonight....
Old Aug 20, 2009 | 09:58 AM
  #67
801bmx's Avatar
back to the knock sensor......
my buddy has AP as well on stage 2 his car was counting 7-15 counts of knock on 91, we then tried it with 110 race gas it still was knocking the same.
I have a completely stock evo 8, we logged my car with an ecu flash program it was knocking 4-6 count under normal driving.
Old Aug 25, 2009 | 04:39 PM
  #68
COBB Tuning's Avatar
When are you seeing these knock counts? Is this under high-load WOT or at low load partial throttle cruising? There isn't enough cylinder pressure at partial throttle low load to cause engine damage, when we get concerned is at higher-RPM high-load situations. See if you can discern when this is happening and under what conditions.
Old Aug 27, 2009 | 08:44 AM
  #69
801bmx's Avatar
This is happening around 5,000 rpm full throttle and 2500 rpm no boost.
I almost wonder if this is just engine noise.
what are your thoughts?
Old Aug 27, 2009 | 09:51 AM
  #70
Low load, high knock is not anything to really worry about. We have noted this behavior in just about every vehicle we support. However, knock at 5000 rpm under WOT is something to take note of and should be diagnosed by a tuner. How much knock are you seeing?
Travis
COBB Tuning
Old Aug 27, 2009 | 11:40 AM
  #71
801bmx's Avatar
He is seeing around 7 counts knock at that RPM.
