Hello From Guatemala, Pls I Need Help Experts With My Pfc
Hello Guys I Need Some Help, I Am Having Probles With My Power Fc Commander For My Evo 7, I Am Lost With My Inyection Maps And Ignition Maps. Its Is Knocking 13 To 17 Right Know, Sometimes It Is More. And My Air Fuel Ratio In High Rpms It Is About 10.3, 10.2 , 10.1, 10.0 It Is To Rich.
My Mods Are, Turbo 20g With 10.5 Tommy Makkinen.
Ejes 264 272
Fuel Bomb 255
Headers, Downpipe
Tuberia De Titanio Of 3 Inches
No Maf, It Use A Sensor Map Of 3.0 Bar
Wideband Blitz Of 5 Volts
Inyestors 750cc Rc Racing
Blow Off Valve Rs Greaddy
Fuel Regulator Sard
Apexi Power Fc
Electronic Boost Control Blitz
Intercoler Ams
Plesase Help Me With My Maps, Also I Need To Know Which Data I Need To Write In Inyector Duty Percent, The Power Fc Came With 100% Each Inyector, Which Percent I Need To Write.
I Attach My Actual Maps For Those Who Want To Help Me
Thanks From Guatemala
Jd
Ejes 264 272
Fuel Bomb 255
Headers, Downpipe
Fuel Regulator Sard
Apexi Power Fc
Intercoler Ams
Jd
Hey JD I'm from Barbados in the Caribbean. I'm no expert but I also have a Power FC on my VII. 13-17 knock is fine. I will be tuning mine for a threshold of 25-30, I know some guys who tune for 40, but anything over that and it's risky. Apexi says damage will certainly occur at 60 or over so going below is common sense. ARs in low 10's are definitely too rich. You want to be aiming for mid to high 11's on stock boost.
What are your cruising A/Rs? If its running too rich across the map you may just need to change your injector base since it may have been calibrated too rich when the injectors were upgraded. Also what is your regulator psi?
May I ask how you eliminated the MAF?
(P.S. Your map contains no data.)
clip14
May 18, 2016 10:57 PM
