which wideband to use for logging and tuning
AEM UEGO its cheap
However, based on this thread I would not call the AEM UGEO a plug-N-play by any stretch.
I'm still looking for a real plug-N-play W/B solution for the EVO.
the LC-1 is about as close to plug-n-play as you will get. It doesn't require a gauge and the 5v output can be sent to the ECU for logging without the extra serial cable. It's a little more work to do the 5v input, but it's a super clean execution.
edit: I was planning on going with a LC-1 but after seeing all the issues, and hanging out on their forums, and then having a friend who's good with electronics and has one as a paper weight tell me how bad they are - i jumped on the UEGO gauge/controller for $200 off ebay.
That's likely because the wiring diagram for the serial plug is backward ... the diagram is for a male connector (I think) and you are using a female ... so it's mirrored.
