EVO8 low boost (11psi)
Old Aug 10, 2008 | 01:26 PM
Gazika's Avatar
hello , i bought EVO8 from US , when i installed boost gauge , i figured that there is only 10-11psi of boost , where can i find problem?
i found on car HKS full exhaust , blitz bov , tuned manifold , injen intake , big alluminium radiator ...
Old Aug 10, 2008 | 01:56 PM
vaboostn33's Avatar
I bought one of mine and it also came like that. The person didnt re-install the boost solinoid. See if there is only one hose on the actuator and it connects to the pipe on the turbo. If thats the case, then you are only running off the actuator.
Old Aug 12, 2008 | 06:48 PM
MrEvo2nv's Avatar
Hey i did alot of work to my evo didn't have a boost gauge installed and though everything was cool , but when i went to get it tuned i was hitting like 14 tappering to 13 psi of boost. Matt and swift motorsports who tuned my car said it was a bad boost solinoid which tend to go bad in our cars reguardless of miles on the car. another friend of mine with an evo was hitting 11psi just like you. check to see if ur solinoid is still there (its located under the intake against the subframe rails. as long as its there and pluged in more then likely thats ur problem. MBC or EBC will fix that.
Old Aug 13, 2008 | 03:16 PM
Gazika's Avatar
tnx
everything is pluged like it is on vacuum diagram , im trying to get mbc , i hope it will help ...
Old Aug 13, 2008 | 03:26 PM
alloutDSM's Avatar
get a gm 3 port
Old Aug 14, 2008 | 09:39 AM
Gazika's Avatar
hi there , i bought mbc but i want to tell u what happend to me today and heed some advise before i install it...
on firs pic is what happend , second is what i find out , maybe on that u'll find out why my car suddenly gets very fast after boost gauge wire jumps off ... on third pic there is what i've done , after all i get 16psi peak and something like 14psi boost
Old Aug 14, 2008 | 09:49 AM
UT_Evo's Avatar
My solenoid went bad, was doing the exact same thing. MBC solved the problem just fine.
Old Aug 14, 2008 | 09:53 AM
fame118's Avatar
I had the same problem. Boost selenoid it was
Old Aug 14, 2008 | 10:26 AM
Gazika's Avatar
can anyone tell me why actuator was connected to bov? or why car goes high boost when boost gauge jumped off the bov vacuum line?
Old Aug 19, 2008 | 08:17 AM
Gazika's Avatar
up... can anybody answer?
Old Aug 29, 2008 | 11:52 PM
Evolution8RS's Avatar
sounds to me like your tapping the wrong line... somethings definatly wrong when your spiking at ont 14 psi..... you should be tapping into this line on the intake manifold for boost coming into the motor.... youll get a more acurate reading this way....http://www.lancershop.com/customer/pages.php?pageid=14
about half way down youll see the FPR line making a loop on the intake manifold, thats the line to tap into.... good luck
Old Aug 29, 2008 | 11:58 PM
vi3txdr34m5's Avatar
boost solenoid!! lol sound like the prob.. so its runnin on waste gate pressure?? right? lol
Old Sep 1, 2008 | 09:30 PM
used2havahonda's Avatar
the stock lines connecting to the solenoid have little pills in them to regulate pressure...without the pills you running off the actuator- 11psi. That could be your problem or the BCS went bad. Either way a MBC fixes it.
Old Sep 8, 2008 | 08:58 PM
Just make sure you straighten out where you ahve your boost gauge tapped into... If its in the wrong spot, your not going to get an accurate boost reading...
5LEEPERISAH23I
Sep 21, 2016 08:39 AM
bboy_RES
32
Jun 18, 2009 02:26 PM
cinek
11
Oct 16, 2007 02:55 PM
evolutionist
Sep 20, 2003 05:01 AM
Evo11V
Sep 16, 2003 11:43 AM
