Tuning the RED.. Where to stop cranking the boost?
Old Sep 4, 2008 | 12:13 PM
93 3gt vr4's Avatar
I recently aquired the new FP RED. I have begun tuning the car again on pump 93oct, and my question is when do i stop turning the boost up. To my understanding the turbo is much more efficient which theoreticly allow more boost? My mods are 880's, walbro, TBE, & buschur FMIC. I've been setting the boost, i'm at 25psi and the car loves it. How much more do i go, if any? No Knock and afr's 11.5 down to 10.8 up top.
btw full spool at 4k to redline.
Old Sep 4, 2008 | 12:27 PM
nonschlont's Avatar
Originally Posted by 93 3gt vr4
I recently aquired the new FP RED. I have begun tuning the car again, and my question is when do i stop turning the boost up. To my understanding the turbo is much more efficient which theoreticly allow more boost? My mods are 880's, walbro, TBE, & buschur FMIC. I've been setting the boost, i'm at 25psi and the car loves it. How much more do i go, if any? No Knock and afr's 11.5 down to 10.8 up top.
CONGRATS on the new purchase. There are a few threads on this as a few people have also gotten the red. try searchig "fp red" I believe people were pushing 30psi, but I'll let them chime in....
Old Sep 4, 2008 | 01:22 PM
1QYK9's Avatar
It seems to me the limiting factor will be the stock block and how much power it will reliably support. The turbo itself might be good for 30psi (or more) but you are reaching the thresholds of what a stock block will support (especially if on E-85 or C16) at that boost level.
Old Sep 4, 2008 | 08:57 PM
93 3gt vr4's Avatar
Thanks. I guess what im looking for is more information on, more timing vs more boost. I did find some good information here http://www.dsmtuners.com/forums/tuni...g-advance.html
I'm trying to figure what pays off more, without having a dyno to my disposal.
I understand that i'm beging to push the limits of the stock block and 93octane @25lbs.But where do i make those little steps to max it out? I will most definitly back down a little to keep it safe once completely done.
Most of the people with the red have more mods or different fuels. I'm trying to squeeze out what i can with my mods.
The thread that i read from above, people believe there is more to gain from boost than timing?
So another question, is it better to add timing or boost for a high octane map? It seems people tend to run a bunch more timing rather than more boost.
Old Sep 10, 2008 | 07:27 AM
hellcat's Avatar
I've found that this can varry from car to car. For instance, my car likes boost. A friends of mine has the same mods I do and his car will knock 4 -5 counts in places with my map. We can turn the boost down 2 psi, raise the timing and his car will run with mine without knock. To answer your question, you will have to play with both to figure out what your car will respond to the best.
Old Sep 10, 2008 | 10:38 AM
Mellon Racing's Avatar
DLL will help you figure out what the car likes, try 25psi with as much timing as it can handle without knocking with a reasonable AFR. Then bump up the pressure a few psi at a time and shave off the excess timing and fix the AFR if it needs adjustment. Run those logs through DLL and see if it's helping or going nowhere.
Old Sep 10, 2008 | 10:42 AM
hellcat's Avatar
^^^^ great advice!!!
Old Sep 10, 2008 | 10:51 AM
tabio42's Avatar
Suggestion - get an EGT gauge/sensor. EGT's will rise due to a lack of timing advance. Between your knock sensor, your O2 readings and your EGT sensor you can find the optimal boost/timing.
My example may be skewed but - if you turn up the boost and compensate with reduced timing advance to eliminate knock, and your EGT's shoot up - the that means it is too much boost for your octane. This is because you are not able to give the car enough timing advance without knocking at that boost level. You are basically chasing the flame out of your exhaust valves.
Old Sep 10, 2008 | 05:39 PM
1d10t's Avatar
^ Thats a very good point.
Old Sep 13, 2008 | 05:55 PM
93 3gt vr4's Avatar
Thanks guys.. heres my dll. Don't know how acurate it is tho.
Old Sep 14, 2008 | 09:25 AM
odd looking dll, did you let off the gas early?
Old Sep 14, 2008 | 10:29 AM
93 3gt vr4's Avatar
that log was from first to 4th and i only used 3rd gear section of the log.
Old Sep 14, 2008 | 12:39 PM
can you do a proper 3rd gear 2500 to limiter pull on flat ground?
Old Sep 14, 2008 | 02:37 PM
BlueDemon's Avatar
^LMAO!!!
Old Sep 14, 2008 | 02:42 PM
93 3gt vr4's Avatar
for some reason i can't get dll to work with a single pull. It only worked for the 1-4th. I'm also using logworks which seems to be a pain in tha *** to convert to dll. I"m going to use mitsulogger and give it a try. Those seem to work.
razorlab
5165
Aug 11, 2024 07:56 PM
turbotaloon95
29
Jul 12, 2016 07:42 AM
turbotaloon95
Jul 11, 2016 06:54 AM
clubEVO93
Jul 21, 2011 11:39 AM
Tarmac8
Mar 16, 2006 10:29 PM
