need to upgrade injectors for evo9-20g+cams?
Old Oct 4, 2008 | 01:03 AM
erggy's Avatar
Hi guys,
I'm currently running BC 272 cams + walbro 255 at the moment. If I plan to upgrade my turbo to evo9-20g + ETS 3" i/c would I need to upgrade my injectors? I plan to run around 1.5bar max boost.
thank you
Old Oct 4, 2008 | 01:07 AM
Chabada15's Avatar
whats 1.bar in psi? id say if you run over 26psi your gunna be heading towards the stock injectors max...my opinion, i keep my safety margin pretty big
Old Oct 4, 2008 | 05:11 AM
erggy's Avatar
1 bar = 14.5psi
Old Oct 4, 2008 | 06:19 AM
steadly2004's Avatar
With ether bigger turbo or bigger cams is generally accepted that bigger injectors are needed.
arnoldp
May 7, 2015 04:03 PM
Turbojunkie
Feb 12, 2009 09:42 AM
The442GTO
12
Feb 19, 2006 05:58 PM
nitz
Jan 10, 2006 10:50 AM
TwStDeVo
12
Dec 5, 2005 10:06 AM
