AEM Tru Boost controller
Old Nov 25, 2008 | 05:53 AM
adamweldonjohns's Avatar
Originally Posted by buddah2006
i wana set my boost to 22psi, but im dont know what to set the settings to. does anyone kno what to set the SPr, FUL ,SCb ,SCr to cause i need help
Did you read the install manual at all? If you don't have it, you can get it on AEM's website.
But, to answer your question, try setting your SPr (wastegate spring pressure) to 11.5 and unless you've got a scramble boost switch wired, ignore the other two. To tune it, try setting your duty cycle to ~30, make a pull in 3rd gear and watch where your boost goes, then set the duty cycle up or down accordingly. Also, if you're in a cold climate like I am here in VT, you might have to turn down the duty cylce when the snow starts to fly
BTW, FUL is what the end of your gauge sweep is set to in PsI. I.E. - if you set it to 25 psi, the little LEDs will be all lit up around the gauge when you reach 25 psi. Try 25-30 PsI for that - looks pretty good to me.
Good luck!
Last edited by adamweldonjohns; Jan 6, 2009 at 10:03 PM. Reason: Technical innacuracy
Old Nov 28, 2008 | 05:18 PM
SSS's Avatar
SSS
I may try one out.
Old Jan 5, 2009 | 03:25 PM
nikkadanny's Avatar
does anyone know how to set the "b" setting? i have my a set at 24psi but when i go to b and go to prg the settings are the same as A and if i change the spring pressure on b it changes on A..
Old Jan 6, 2009 | 10:05 PM
The a and b settings only differ in their duty cycle
Old Nov 27, 2017 | 07:53 PM
OskarEvoIX's Avatar
I'm willing to trade with anyone who has a tru boost gauge I have a greddy profec b spec2 and I'm not sure what to think about it maybe I'm just to dumb and don't really understand it?
c4s3ys
Oct 7, 2017 04:56 PM
smoothevo
Apr 21, 2017 03:57 PM
ddubdb3
Oct 25, 2016 10:02 PM
Alexevo09
May 5, 2016 02:16 AM
nikush
Apr 24, 2016 03:20 PM
