Autronic Roll Call!
Old Oct 27, 2008 | 08:18 PM
  #31
500hpOnPumpEvo's Avatar
Originally Posted by Whoop_ass
autronic PnP evo 9
Buschur 2.3 stroker
Full race GT4088r TS
jumping bank account bat man!
Thats like 20K in 2 lines lol!!
Old Oct 30, 2008 | 10:10 AM
  #32
Whoop_ass's Avatar
ye ...
now i will be eating rice for the next 2 years
Old Oct 30, 2008 | 10:27 AM
  #33
Balrok's Avatar
ye ...
More like ramen lol.
Old Nov 8, 2008 | 04:03 AM
  #34
casper980's Avatar
Guilty...I am using an Autronic SMC 1.99 pnp, waiting to take it to AMS for final tuning and concrete numbers. I am hoping for 450whp on 93 and over 500 on 110 here is my modification list...I think I am half way there
Block
Custom Built 2.0L by AL of Motor city Muscle/Rhino Heads
CP pistons .20 Bore 9.0:1 compression
Brian Crower Pro Series Rods
Cosworth Main, Thrust, and Rod Bearings
Cosworth Crank Scraper
AMS Racing Balance Shaft Eliminator
Perrin Crank Pulley
Head
Port and Polishing done by Al of Motor city Muscle/Rhino Heads
BC nitride coated Valves W/3 way competition valve job
WORKS 269 Cams
WORKS TI Retainers and Valve Springs
ARP Head Studs
Air
Apexi IHI RX6B (TCW77-P22~TS GT3240)Turbo Kit Customized by DJT Motorsports
Perrin Intercooler
RS*R GT2 Exhaust Magic Cat-Back Exhaust
Dejon Tools MAF Eliminator Intake w/K&N Filter
HKS Upper intercooler Pipe w/ SSQV
Greddy Cold side Intercooler pipe
DJT Custom lower intercooler pipe
Fuel
RC injection 1000cc
Walbro 255L Fuel Pump
Electronics
Autronic SMC 1.99 Plug and Play
AEM Boost Solenoid
Defi BF Boost Gauge
Defi Control Unit II
Magnecore Spark Plug Wires
Braille no weight Battery W/DJT Battery Tray
NKG step colder
Brakes
AMS Brake Ducts
Ferodo DS-2500 Street Pads
PFC97 Race Track Pads
Roto Pros slotted and dimpled
DJT Custom SS braided Brake lines
Motul Brake Fluid
Suspension
Hotchkis Rear Sway Bar
Works Front Strut Tower Bar
RS Trunk Bar
DJT Lower Tie Bars front/center
White Line Lower Control Arm Bushings
Transmission
Exedy Hyper Twin Clutch and Flywheel
Perrin Short Throw Shifter
Speed Source shifter endlinks
Kart Boy Shifter Base Bushing
DJT Custom SS Braided Clutch Lines upper and lower
Misc.
Beatrush Under Tray
DJT Custom Harness Bar
Team Tech 6 Point Rotory Release Harness'
SP Engineering CF Radiator Cooling Plate
Rota Torque W/Eagle F1 DS-D3 stock size
Stock Rims W/Blizzack LM-25's for Winter
Greddy Gracer Front Lip Spoiler
AMS Front Engine Mount
AMS Cam Gear Engine Mount
Greddy Timing Belt
Tomei Oil Thermostat Killer
Bosch Wide Band o2 Sensor in mid pipe
All Fabrication and Installation done by Darin Stocker of DJT Motorsports
Old Nov 8, 2008 | 04:21 AM
  #35
space's Avatar
whats the anti-lag and launch control like with the autronics units, any experiences, please share?
Old Nov 9, 2008 | 12:03 PM
  #36
casper980's Avatar
autronic ecu's are used by many rally teams, for many reasons one of many is the superior launch control and anti lag. however one needs to be well versed in the setup gain desired results. one feature of the anti lag is to have anti lag kick on when the ecu sees a given rpm. so at a stand still you can rev the engine and anti lag will kick on for 30 secs so you can launch, but stay off while stopped at a light in traffic, when you don't necessarily want anti lag on.
Old Nov 14, 2008 | 08:25 PM
  #37
genma's Avatar
I will be defiantly looking into the Evo 9 PnP unit, here in Hawaii there is supposedly a very reputable Autronic Tuner / Dealer. Justin Izumi of Izumi Racecraft..
Old Nov 18, 2008 | 08:30 AM
  #38
If you have someone that actually knows how to tune anti-lag OMFG its sick!!
Definitely made my pants tight..
Old Dec 6, 2008 | 03:23 AM
  #39
casper980's Avatar
Originally Posted by diablo2184
so the guy in charge now isn't very innovative?
Someone needs to get in there. That's the only thing I'm afraid of with Autronic...the customer/technical support. Aem has great support, has anyone tried Autronic since Hall left?
The same guy is in charge...Richard Aubert, he is the founder of Autronic. Ray Hall was the person that started the Mass distributing and creating new vendors, the web site, he moderated the forum, techinical support on Autronic hardware, stuff like that. Ian Hamwood, took over, a long time Autronic employee, I forget what he used to do. Autronic is a very small company, with a dedication to what they do. They don't have magazine add campaigns and you will not find there name on a car because they are sponsoring them. They just LOVE cars, bikes, boats, you name it and make some of the Highest Quality ECU's that you can buy. If you call Autronic Austrailia you can get him on the phone, no problem. Try calling the founder of AEM and get him to help you with injector settings!
Old Dec 13, 2008 | 07:29 PM
  #40
thebluesky's Avatar
I'm also an Autronic user. I actually learned how to use it at EFI 101 and fell absolutely in love with it.
I'm in the middle of my build now, but I'm going to go pretty big with it.
Mods:
2.3 stroker wit knife-edged crank, fully balanced rotating assembly
GSC S2 cams,
In-tank twin pump setup
HKS DLI2
HTA 35r turbo
1600cc injectors
etc....
Old Dec 14, 2008 | 02:17 AM
  #41
crcain's Avatar
Me and my 2 other friends run Autronic... all Evo 6.
Mine: SM4, MAD Spec Piper cams, AMS 35R, 2.4l, etc (10.7 on race)
Buddy1: SM4, Revolver, Green, 2l, etc (11.0 on race)
Buddy2: SMD PnP, HKS 272, Buschur 2l long block (11.5 on race)
All tuned by Mark Shead at MADevelopments. Thanks Mark!
I've spent a few minutes with AEM software. What a clunky, ugly P.O.S However it prolly gets better once you learn it properly. Autronic is slick and fast software. You map the fuel table by VE and I swear you could map the fuel table with one number and it would probably be pretty close. Also no long startup cranking and cranking. Stock like turn over or very close to it. No knock control though
Also I don't know if this says anything about the ignition outputs but I've run 41 psi on stock coils Never had any miss. Denso Iridium plugs as recommended by Mark. Had to go to a go kart store to find a place doing them online
Old Dec 17, 2008 | 01:23 PM
  #42
UK_EVO4's Avatar
Evo 4 Autronic pnp mapped by NR Autosport.
Old Dec 21, 2008 | 11:27 PM
  #43
BlownIncome's Avatar
I was using Autronic (SM3 version I believe) for a while until one of my sensors went out. I sent it in and haven't heard anything about it yet and that was basically close to a year ago now. From what I can see the unit is great but the support or lack there of is pretty poor IMO. Anyway, I made 449 whp at 21lbs. on pump with that ECU and my current set up. Now I'm running Ecuflash at 25lbs. and making pretty much the same if not a tad bit more it would seem. I think with Autronic you can control the timing and fuel better than you can with the AEM system.
Old Dec 25, 2008 | 01:29 AM
  #44
alex4nder's Avatar
Send a mail to Ian Hamwood (customer@autronic.com.au), and ask him what's gong on. He's extremely responsive.
Old Dec 25, 2008 | 03:16 AM
  #45
casper980's Avatar
You can also call him /\ 01161407917269 can be a little pricey if you don't have international calling. He is also a little hard to understand sometimes.
