How to read ECU error codes with EVOSCAN ?
Old Nov 29, 2008 | 01:16 PM
fireroasted's Avatar
This is probably been answered a milliong times, but a quick search didn't yield me an answer. I am trying to figure out how to read ECU error codes with EVOSCAN or ECUFLASH. I have a SERVICE ENGINE SOON light on and trying to troubleshoot some new after track day noises. I just realized I haven't figured out how to read the error codes. Any info on how to pull that from the ECU would be great.
Thanks
M
Old Nov 29, 2008 | 07:52 PM
~BoOsTeR~'s Avatar
EvoScan has it down in the right hand corner ("Read DTC's)
Old Nov 30, 2008 | 05:40 PM
Holy Crap. how did I miss that. Ok I justify my moronic post in that the title will make it very easy for another moron like me to find the answer really quick.
Thanks
M
Old Sep 11, 2010 | 10:13 AM
yorT's Avatar
Bringing this back but I also have a "Service Engine Soon" light on and when I try to read DTC using EvoScan it says everything is okay. Is there something I am doing wrong? I need to figure out why my car is idling up and down and coming close to shutting off. Thanks.
Old Jan 25, 2011 | 07:18 AM
tlsole's Avatar
^ Same here, but my idle is fine. I just got tuned, anyone have a clue?
Old Jan 25, 2011 | 11:54 AM
Boosted Tuning's Avatar
EVOscans DTC feature is temperamental. I have the best results doing the following:
With cable hooked to car and laptop, turn key to the "on" position and open EVOscan. As SOON as you open EVOscan, press the "Read DTC's" button. Then it will usually work.
If you have already had EVOscan open, it may not work. You may need to close it and do what I said above.
Old Dec 15, 2011 | 02:24 PM
mrboost05's Avatar
boosted tunning was on the money that was the only way i could pull my codes
Tuxevo
Jun 25, 2016 09:01 PM
stunt2
Sep 28, 2015 03:15 PM
Smalls
Aug 9, 2014 02:38 PM
X Double Dot
Oct 21, 2013 08:18 PM
GiGas
Oct 1, 2009 02:27 PM
