check engine light on
Old Jan 4, 2009 | 05:09 PM
mungro23's Avatar
my check engine light is on and i cant pass inspection. the said it has to do wit my o2 sensor is there a bypass or away to clear the light so that i can past inspection. please dont tell me to disconnect the battery. any info will be great thaxxxx
Old Jan 4, 2009 | 05:18 PM
Smike's Avatar
OBDII scanner. Need to know which code - front or rear. Do you have any mods?
Old Jan 4, 2009 | 05:33 PM
X91EVO's Avatar
Registered User
or get the now discontinued perrin cel fix.. it connects to your oxygen sensors wires and fools the computer with a perfect reading.. you can probably find some on around here or other websites
Old Jan 4, 2009 | 06:27 PM
mungro23's Avatar
yes i do have mods it start when i put the down pipe in and its the front sensor....and what is the discontinued part calld
Old Jan 4, 2009 | 07:05 PM
X91EVO's Avatar
Registered User
the perrin cel fix.. heres a link where to buy one..
http://www.highperformanceoutlet.com...-WRX%2C/Detail
Old Jan 4, 2009 | 08:54 PM
MacksEvo's Avatar
Its an easy and cheap fix. $4. to be exact. Go to the local Advance Auto Parts, buy Spark plug non foulers, thread you 02 into the non foulers and the non fouler into the exhaust and the sensor will go off...
Old Jan 5, 2009 | 05:02 AM
mungro23's Avatar
thanx for the help
jk_evo8
Northeast Region
Apr 13, 2016 05:38 AM
Jaxson75
Lancer Troubleshooting
Jun 29, 2015 06:13 PM
Nickbevox
Aug 22, 2014 06:05 AM
impact blue
Mar 1, 2012 07:12 PM
.MM
May 17, 2010 08:38 AM
