Climate Control Electrical Help! Please!
Old Mar 4, 2009 | 11:42 AM
HarryPerth's Avatar
Hi,
Recently I have lost my EVO 8 car keys and being in australia i was unable to get a new key as the transponder just wont code to the ECU. I so then decided to put in a HKS V-PRO in the car to by pass the factory immobliser settings and everything is working fine except the AirCond (Climate Control). When i turn on the air cond its just blowing air. I therefore take it that the condenser is not running. How do i eliminate the condenser wiring from the Factory ECU to the HKS V-PRO? what wires or pins do i need to remove? All the mitsubishi manual and electrial diagrams i been given does not have climate control wirings. Could someone please assist as your thoughts and help would be appreciated.
Or if you could provide other alternatives. So far I been told that one way is to find someone who has crack the factory ecu? Or find someone who knows how to bypass the factory ECU to give an output signal cause there is an immobliser.
Thanks.
Old Mar 4, 2009 | 12:25 PM
andrewzaragoza's Avatar
i do not think that the aircon is connected to the ecu. check your fuses. when you turn on your aircon does your aux fan start up. if it doesnt its probably a fuse or a relay.
Old Mar 4, 2009 | 12:36 PM
HarryPerth's Avatar
Its just blowing air normal blower air. What i was told is that the condenser is linked to the factory ECU and its immoblised. I therefore need to de-immoblise it for it to work and this aint gonna happen cause i have lost my keys so factory immobliser is null and void.
LeXcite
Jan 17, 2022 08:05 PM
EvoDan2004
17
Jul 4, 2014 10:42 AM
EvoDom
Oct 23, 2011 06:15 PM
Creamo3
Midwest Region
26
Jul 9, 2010 07:25 AM
blackfly
11
Feb 23, 2010 11:04 AM
