How normal is this!!! LEAN..
Old Mar 12, 2009 | 01:15 PM
ant_turbo's Avatar
Is this normal...
My car is a evo 9 running on 91 octane and spike 22psi and running lean like in the med 12's @ WOT,,,,,,My tuner tried tuning it adding more fuel but it didn't help!
The injectors where maxing out above 90% and that wasn't even by redline...
MOD'S ARE
Hks 272 Cams Springs/retainers
255 Walbro
3' DP/ TestPipe Catback
Injen intake with Hks open filter UICP stock LICP
Old Mar 12, 2009 | 01:26 PM
Jay644's Avatar
I think you need to upgrade to bigger injectors. If your tuner doesn't realize this then you should probably find another tuner.
Old Mar 12, 2009 | 01:30 PM
justa4banger's Avatar
What he said^^....if your running that lean stop getting on it,save your pistons before u melt one
Old Mar 12, 2009 | 01:33 PM
ant_turbo's Avatar
Ya my tuner did say to get BIGGER INJECTORS...
I was wondering if it was normal in my case....
THANKS,,,,,
Old Mar 12, 2009 | 01:37 PM
Well its NOT normal...that's even lean for e85 or race gas or meth
Old Mar 12, 2009 | 01:44 PM
TeStUdO's Avatar
If you are on the stock turbo, I don't see the injectors being maxed out at 22psi. What type of loads are you hitting and is your MAF scaled with that intake?
Old Mar 14, 2009 | 09:46 AM
I<3Boost722's Avatar
Do stop going WOT while your cars in this condition.
Or you wont only be worrying about fuel before long
Old Mar 14, 2009 | 09:59 AM
smokedmustang's Avatar
You wont max out those injectors with your setup, the problem is something else. Only reason you need bigger injectors is when you get a bigger turbo, OR a stroker motor. Using those mods, your injectors are big enough for the job with those mods.
Old Mar 14, 2009 | 10:41 PM
ant_turbo's Avatar
I think it might be ehter my injectors or walbro.... Because when I put in racegas for track days...I hook up a hose from the fuel return into a can and wait till the cars dies..and drian all the pump gas... May injectors are dirty or fuel pump is going bad,,,,,, Anyway Im gonna buy a new walbro and clean my injectors...
Old Mar 18, 2009 | 07:55 PM
Gumby56's Avatar
yikes i just got 880s mmhmm
Old Mar 19, 2009 | 04:50 AM
EvoDom's Avatar
if i were you i would find a new tuner.
Old Mar 19, 2009 | 10:10 PM
TakaseEVOIXSE's Avatar
FYI everyone's definition of MAXED out (on stock injectors) is DIFFERENT. Generally speaking (for ALL CARS) you should try NOT to go above 85-90% duty cycle. Sure majority of the guys here go into the high 90's even 100-120%... but i personally wouldnt recommend it. Got a weird lean condition and can't figure it out?? Take it from me... get a voltmeter and test the resistance on all of your stock injectors. Trust me... i've turned a set of stock injectors static w/ just an intake/exhaust/tune on 24psi. It can happen. 1)the stock injectors are grossly unbalanced from the factory. My print out from RC engineering read like 530, 540, 560, 562 (cc readings). When stock should be 560cc. After they balanced them, they were all at 560. Anyways, resistance was reading 3.5 ohms or a tad higher. After racking my brain for months on a new pump, new tune, etc etc... i cured the problem w/ a set of pte780s and a retune. It WAS the injectors in my case. And yep it was an uncontrolled low to mid 12afr spike in a certain rpm range...
jtbell86
11
Aug 1, 2020 09:23 PM
mct9891
Jul 12, 2012 10:14 AM
Spish
26
Dec 29, 2009 01:24 PM
M3this
12
Feb 27, 2007 09:38 PM
evo8fl
Jan 10, 2007 08:49 AM
