TBE+tuning?
Old May 11, 2009 | 01:48 PM
theboricua's Avatar
TBE+tuning?
Installing a TBE ( downpipe, test pipe, catback and muffler 3'' stainless steel) on wedsnday, do I have to tune the car for just the TBE? the car is stock other than the TBE, considering getting a COBB AP later on. Cuase if I have to tune ill wait cause i need the vehicle and dont have the money for a tune or AP.
Old May 12, 2009 | 08:31 AM
turbolarry's Avatar
You do not have to tune to run around with a turbo back exhaust.
To get the most power, and fun, out of the increased exhaust flow; yes you will have to tune, but like you said you're doing later on.
After the exhaust is in try disconnecting the battery for a few minutes. It resets the ECU, will have to relearn some fuel trims, and should run a little better.
Make sure you have something for for the check engine light that will come from the test pipe.
Old May 12, 2009 | 10:27 AM
theboricua's Avatar
Something for the CEL? is there a way to not make it go on?
Old May 12, 2009 | 11:04 AM
TwoFour's Avatar
Yes, weld in a bung for the stock o2 sensor. Or just get a wideband and weld the bung just before the test pipe, on the downpipe. Then delete the stock o2. Search on the forums on how to do all of that.
Old May 12, 2009 | 04:02 PM
theboricua's Avatar
awesome thanks!!
m0nkie
Aug 15, 2013 12:39 PM
GsrJake
Dec 20, 2012 12:32 PM
Fooj Evo x
Cobb AccessPORT
Nov 16, 2011 06:30 AM
pupo
28
Jun 6, 2009 02:55 PM
elphalba
Jun 24, 2008 07:37 PM
