Automatic ECU Tuning
Old Jul 29, 2009 | 09:04 PM
Rych's Avatar
Question Automatic ECU Tuning
Hi,
I've been wondering why both times I have put an exhaust and intake on my cars, I haven't noticed the major power increase untill a day or two later. I was wondering if the factory ECU adjusts to the new flow of air / boost / fuel etc own its own? Would this be true, because the first time I drove my old sti and current evo after modifying it I didn't really notice the major difference straight away.. It's like the ECU adjusts after a few drives and gives itself a small tune.
Would this be correct?
Old Jul 30, 2009 | 08:17 PM
lilredevo's Avatar
i think the ecu will try to compensate for more air in and freely flowing exhaust to a certain point. it can adjust itself out to run as best as it can with the set peramiters it has in th ecu
Old Aug 1, 2009 | 08:24 PM
CoMoEvo's Avatar
this is why most people (i believe most) will put those parts on, disconnect the neg. terminal on their batt., and then let the card idle for 5-10 minutes. i noticed an instant difference with just intake, tbe, and licp.
Old Aug 6, 2009 | 06:56 PM
vigilante.zen's Avatar
As far as I am aware the ECU doesnt correct for these items. A tune is needed to correct the rich/lean after such installs. The evo runs rich from factory so assuming you put a filter on doesnt help the problem. Hope that helps.
qsiguy
Dec 29, 2015 01:57 PM
tvor
Aug 20, 2015 02:10 PM
project_skyline
Sep 13, 2012 11:50 AM
Honto
Sep 8, 2012 06:29 PM
modetm
Jul 23, 2009 09:36 AM
