All knocked up
Old Sep 27, 2009 | 07:10 PM
njboy's Avatar
All knocked up
Just wondering what many of us who self tune are running with regards to knock sums and what is considered safe. The self tuning sticky thread talks about removing all knock and going for almost zero with the occasional 1-2 knock. A tuner that I talked to said that knock of 5 is low and ok. Do some of you run 7-10 knock sums? I'm currently running a safe tune but if I advance the timing 5* the car feels much faster but the knocks are high (5-7).
Old Sep 29, 2009 | 07:58 AM
tephra's Avatar
at WOT less than 3KS is ok - as long as its inconsistant.
if your consistantly hitting 2KS in a certain spot (rpm/load) drop the timing by 1 degree
Old Sep 29, 2009 | 08:01 AM
Lancerguy'03's Avatar
you will get some knock at spool up though...that is not bad. bad knock mainly occurs at the top or the rev range... right guys?
Old Sep 29, 2009 | 08:04 AM
tephra's Avatar
spool knock will persist into your WOT run which will reduce power.
if its consistant spool knock then tune it out, either check your AFR or reduce timing to avoid the knock
Old Sep 29, 2009 | 08:14 AM
alright cool. ill keep an eye on my knock light
Live4Redline
Jul 17, 2024 07:09 AM
mrfred
39
May 18, 2011 05:05 PM
ArtofRalli
May 9, 2011 09:37 PM
mlancerevo8
Oct 17, 2008 12:23 PM
tkklemann
Apr 28, 2007 05:52 AM
